If you're looking for a basic case for your Motorola Droid X, check out the Smartphone Experts Skin Case. It has a slim and sleek design that gives your Droid X a simple layer of protection without taking away from the design of the phone, or adding any bulk.
The case is made out of a durable and flexible rubber-like material with a special anti-dust coating. It provides a bit a grip, but not so much that it feels sticky. The phone slips inside, covering the entire rear, top, bottom and sides. Your Droid X's screen is uncovered, but the slight extra thickness of the case helps keep free of scratches when placed face-down.
There are cutouts for all of the Droid X's buttons and ports -- including the all-important noise-canceling microphone on top of the phone. And it looks good, too, with a diamond-argyle pattern, which makes the case -- and your phone -- stand out from all the rest.
The Smartphone Experts Skin Case for the Motorola Droid X is available for $9.95 from the Android Central Store. More picture of it in action are after the break.
3329(forum posts)
