Verizon this afternoon confirmed that four of its CDMA Android smartphones will receive software updates that allow them to connect to GSM networks outside the United States. The phones are the HTC Rezound, the Motorola Droid RAZR and RAZR MAXX, and the Motorola Droid 4. All four of the phones phones are 4G LTE capable and thus have SIM cards, which generally is a hallmark of a GSM device.
Said Verizon:
Customers will see a notification on their device when the software update is available for their device. After the software update, customers will be able to take their smartphone overseas and use voice service in more than 220 countries and receive data in more than 205 countries.
Of course, you'll need to add some global service to your Verizon plan. Or, and this is the really good news -- Verizon tells us the phones already are SIM unlocked, so you should be able to use a prepaid SIM once you're in-country. If you don't travel outside the U.S., well, you can just go about your domestic business.
- Related devices:
- Filed under:
- Tags:
3331(forum posts)
