One of the big blunders of Samsung's Gear Fit was that the screen was horribly annoying to read in the horizontal orientation while on your wrist. It just didn't look right and you have to shapeshift your arm to be able to read it straight on.
With a quick update however, they've added a new option that lets you change the orientation to vertical instead — making things much easier to read. Of course if you like the horizontal layout better, that option is still there as well.
Check out the video above where Phil gives us a quick look at how to get it done. A few quick taps and it will feel like a whole new device — or maybe just a newer device since it's technically new already.
