What's the best OBDII reader for Android? Here's a few to get you started!
Car repair can be costly (DUH) and that Check Engine light could mean myriad issues with your car. Or, it could be a simple fix that you could do yourself – so why take it to your dealer or mechanic without knowing the problem first? Some places will charge you $100 or more just for the scan.
Don't get swindled again. Get yourself your very own Bluetooth OBDII reader/scanner and figure out what's wrong with your car, right on your phone or tablet!
BAFX Products 34t5
BAFX Product 34t5
The BAFX Products 34t5 claims to work on all vehicles in the U.S. from 1996 or later, so chances are that if you're driving, this will work with your vehicle. All you need is a third-party app (which range from free to rather expensive paid apps), and you can connect the 34t5 to your Android phone or tablet to read out diagnostic information.
While reading out diagnostic codes, you can even clear them out at will, thus turning off your check engine light – even for manufacturer-specific codes!
Depending on the third-party app your choose, you can get real-time sensor information right on your phone, life speed, balance rates, RPM, O2 readings, and lots more.
If you feel the need for speed, this reader will even send you ⅛, ¼, ½, and 1 mile times.
Don't spend $100 just for someone to scan your car; spend about $22, read it yourself, and maybe you'll even be able to fix it on your own!
See at Amazon
Panlong Car Diagnostic scanner
Panlong
Panlong's small OBDII scanner is perfect for the do-it-yourselfer on a budget – you can find these on Amazon for around $13.
This reader will work on any car sold in the U.S. from 1996 or later – it just might not work with some hybrids. All you need is a third-party app, like Torque or DashCommand and you'll be able to read and clear trouble codes, while receiving real-time data readings – and you'll be able to turn off that damn Check Engine light!
If inexpensively is the way you like to maintain your vehicle (who doesn't?), then opt for the Veepeak Mini scanner.
See at Amazon
ScanTool OBDLink LX
OBDLink LX
The ScanTool OBDLink LX is a professional-grade OBDII reader that features its own app, which allows you to scan, read, and clear trouble codes in all cars sold in the U.S. since 1996 (except hybrid or electric vehicles).
All you have to do is plug it in, pair it with your phone, open the app, and you'll see real-time diagnostic data, as well as information about performance.
You can even use your Windows PC to access and compile your information without ever having to see a mechanic. Fix the stuff you can fix yourself and only take it in when absolutely necessary.
Being a professional tool, the OBDLink LX claims to service a wider range of vehicles, given more complex algorithms, and the Amazon reviews seem to agree.
It may be about $50, but if you love your car and worry that the cheaper readers might not actually do the trick, then check out the OBDLink LX. $50 is better than the $100 the dealers will charge you!
See at Amazon
iSaddle Super Mini
iSaddle
The iSaddle Super Mini supports all OBDII protocols and works on just about every car sold in the U.S. since 1996 (except hybrid and electric), allowing you to diagnose what ails your vehicle to help determine whether or not it really needs a trip to the shop.
For Android users, iSaddle works exclusively with the Torque app feeding you diagnostics and performance data via Bluetooth.
If you're unsure about the DYI approach to car repair, the iSaddle's only about $12, so you really have nothing to lose if you want to try it out yourself. If you can fix the problem yourself, go for it, but you still have the option of taking it to your dealer or mechanic if you're out of your element.
See at Amazon
What do you use?
Do you read your car or truck's trouble codes with another scanner that we didn't mention? Do you read your own codes or just take your car to the shop whenever the Check Engine light comes on?
Let us know in the comments below!
