These TESSAN towers and power strips are the Power Rangers of multiplugs and they can be yours for 23% off this Black Friday
Various TESSAN power strips, towers, and plugs
(Image credit: TESSAN)
Don't you hate it when you've run out of wall plugs to power up your electronics? As a tech journalist and avid tech enthusiast, I have two of TESSAN's fantastic towers in my home. The TESSAN Tower Power Strip Flat Plug with 11 Outlets is my weapon of choice as it not only adds more plugs, but also has one USB-C and two USB-A ports.
If you're in dire need of wall plug extensions, you need to take advantage of this Black Friday deal and score a neat 20% off the TESSAN Tower Power Strip Flat Plug with 11 Outlets. Your housemates, family members, or friends will thank you for it. No more fighting over who gets to plug in their thing!
TESSAN Tower Power Strip Flat Plug with 11 Outlets 3 USB (1 USB C)
Save 20%
TESSAN Tower Power Strip Flat Plug with 11 Outlets 3 USB (1 USB C): was $29.99 now $23.99 at Amazon
This tower from TESSAN has 11 outlets, extending a singular wall plug safely via surge protection. Available in black and white, it also sports two USB-A and one USB-C port. With a maximum power rating of 1625W/13A, you can choose from 5ft, 6ft, 10ft, and 15ft cord length options.
TESSAN Surge Protector Power Strip, 5 Ft Flat Plug Extension Cord with 3 USB (1 USB C) 8 Outlets
Save 23%
TESSAN Surge Protector Power Strip, 5 Ft Flat Plug Extension Cord with 3 USB (1 USB C) 8 Outlets: was $24.74 now $18.97 at Amazon
Looking for a flatter form factor that can fit in narrow spaces, nooks, and crannies? Check out TESSAN's Surge Protector Power Strip 5 Ft Flat Plug Extension Cord with 3 USB (1 USB C) 8 Outlets. As you can tell by the tedious product name, it adds eight outlets, one USB-C and two USB-A ports, and a 5ft cord. The power rating on this strip is 1250W.
TESSAN Surge Protector Flat Extension Cord 5Ft, Flat Plug Power Strip with 4 Outlets 3 USB Ports (1 USB C)
Save 21%
TESSAN Surge Protector Flat Extension Cord 5Ft, Flat Plug Power Strip with 4 Outlets 3 USB Ports (1 USB C): was $20.24 now $15.98 at Amazon
If you don't need as many outlets, then opt for the smaller and cheaper TESSAN Surge Protector Flat Extension Cord 5Ft, Flat Plug Power Strip with 4 Outlets 3 USB Ports (1 USB C). It only adds four plugs, but you still get one USB-C and two USB-A ports built-in. This model is 21% off while this deal lasts.
✅Recommended if: Your home has terribly placed wall plugs in hard-to-reach spaces, and you require a lot of outlets.
❌Skip this deal if: You don't want to add so many outlets as the more you have, the more devices you'll keep plugged in and increase your electricity bill.
TESSAN's power strips all have flat plugs, so they are ideal for tricky corners and tight spaces. If the wall plug placement in your home is terrible, you can get a couple of these towers and strips to make those plugs easily accessible.
Instead of pushing the bed, couch, or table every time to plug and unplug an adapter, you can simply set up TESSAN's multiplugs or towers in strategic locations around your house. I like to keep the 11-outlet tower under my office table as I usually have a million devices plugged in. The flat strip is perfect for the bedroom as it can sit behind your bed or on your bedside table.
You don't even need to worry about overloading these extensions, as all of them come with surge protection and very high power ratings to begin with.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
