We're seeing a ton of great deals on headphones this Prime Day. Whether you're a frequent traveler looking to block out all of that noise on your next flight or a gamer looking to up your experience with surround sound audio, there's no better to buy a new set of headphones. Here are some of the best deals we could find!
Active noise-canceling: Sony WH1000XM3
Staff pick
The 1000XM3 are some of the most popular noise-canceling headphones around. They sound great and block out virtually all surrounding noise, and you can put your hand over the right cup to selectively let noise back into the headphones.
$298 (was $350) at Amazon
Noise canceling on a budget: Tribit XFree Tune
The XFree Tunes are affordable headphones with hi-fi audio that can be used wirelessly or plugged directly into an audio source. They're great for travel, with built-in passive noise-cancellation, and last for up to 40 hours from a full charge.
$40 at Amazon
RGB built in: Corsair Void Pro RGB
The Void Pro headphones are Discord-certified, with excellent audio, Dolby 7.1 surround sound, and a built-in microphone for communicating with other players while gaming. They're wireless and built for comfort, and the logo can light up with different colors.
$60 (was $100) at Amazon
Surround sound: HyperX Cloud 2
These USB headphones are built for gamers, with a detachable noise-canceling microphone and Dolby 7.1 surround sound audio. They feature 53mm drivers and memory foam earpads, and they can even work with your Xbox One or PS4.
$70 (was $100) at Amazon
Premium quality: Astro A50
The Astro A50 boasts crystal-clear Dolby 7.1 surround sound audio over a 5GHz wireless connection that is nearly unbeatable by any of its competition. You'll even get a charging stand with your purchase so you can display it with pride.
$200 (was $300) at Amazon
Lossless audio: SteelSeries Arctis 7
The Arctis 7's claim to fame is its lossless wireless audio, with low latency and Discord certification. The S1 speaker drivers inside help deliver crisp, clear audio, and the headphones feature Dolby 7.1 when connected to a PC — though you can use them with an Xbox or PS4, as well.
$100 (was $150) at Amazon
Dual device streams: Bose SoundLink II
Bose is one of the leading brands when it comes to headphones, and the SoundLink IIs feature an advanced microphone system with wind and noise cancellation for making clear phone calls. They also support up to two Bluetooth connections at once for easy device switching.
$159 at Amazon
Quick pairing: Beats Solo3
The Solo3 is slim, stylish, and folds down to a compact size for travel. These headphones last for up to 40 hours on a single charge and can go for another 3 with just a 5-minute charge. If you have an iPhone, they also pair incredibly easily thanks to Apple's W1 chip.
$220 (was $300) at Amazon
Digital noise-canceling: Sony WH-CH700N
Sony headphones don't have to be expensive! The CH700N have superior comfort to even the more expensive 1000XM3, and sound great for the money. They also offer digital noise cancellation, Amazon Alexa voice assistance, and 35 hours of playback on a single charge.
$90 (was $200) at Amazon
Smart ANC headphones: Microsoft Surface Headphones
The Surface Headphones are excellent noise-canceling cans with a unique design and a convenient rotating dial for adjusting volume and other controls. There's a built-in voice assistant, and you can adjust the intensity of the ANC on a whim.
$249 (was $350) at Amazon
Don't wait around on these deals
Prime Day only lasts until the end of Tuesday, and some of these deals may even run out before then, so if you've been considering one of these headsets, there's no better time to pull the trigger.
Prime Day may have ended, but these 25 deals are still available now!
If it were our money, we'd go for the Sony WH1000XM3s, which offer a perfect blend of great audio quality and some of the best active noise-canceling we've ever heard in a pair of consumer headphones. They're perfect for travel, or just working out of a noisy coffee shop.
We may earn a commission for purchases using our links. Learn more.
