The Space is Samsung's 32-inch 4K monitor and it's down to $379.99 on Amazon for Prime Day. The monitor normally sells for around $430 and was going for as much as $470 in May. It has never dropped below $430 until now.
All Four of the Ks
Samsung S32R750 32-inch The Space 4K monitor
Called "The Space," and designed to save you as much of it as possible. This is the lowest price we've seen.
$379.99 $430.00 $50 off
The monitor is designed to eliminate all the extraneous parts on other monitors. It uses an integrated arm stand so it can be propped on the edge of your desk instead of using a stand that sits on top of it. It eliminates the bezels on the side for a near frameless display. The 4K resolution gives you stunning images, too.
We may earn a commission for purchases using our links. Learn more.
