Tired of switching cases on your Nexus S (all models) anytime you need something extra rugged? The Seidio CONVERT Combo case for the Nexus S is something you'll want to have a look at. The first layer is the smooth and slim Seidio Surface, which offers a tasteful look and protection enough for everyday use, but combined with the top layer of rugged silicon skin and the plastic skeleton frame makes it perfect for outdoor activities or use on the job. Top it off with the face-in belt holster and included screen protector, and you're ready for anything.
In either configuration you have access to all the ports and controls, and while the tough rubber skin is on everything is covered by a protective flap to seal out the dirt and dust. These are easily opened for access to anything you would need to do, whether it be snapping a quick picture or using the microUSB port. The headset jack has it's own cut-out, so the protective flap can be closed while you're jamming out or using a wired headset.
The included belt holster swivels and locks in place in seven different positions, so you're sure to find the one that feels just right. It's also a great way to carry your Nexus S in the car while clamped to the sun visor. The holding clip locks in place to keep it from opening when you don't want it to, but a quick flip of the latch allows you to open it easily. No matter which flavor of Nexus S you're rocking, the Seidio CONVERT Combo case kit will give you just the amount of protection you need, and looks good while doing it. Check out a slew of pictures after the jump, and grab it in the Android Central store for $47.95.
- Related devices:
- Filed under:
- Tags:
4817(forum posts)
