Samsung Galaxy S26 Plus vs. Galaxy S24 Plus: An upgrade worth waiting for?
Samsung's top-of-the-line smartphones generally hold up quite well over time, and the Galaxy S24 Plus is no different. Even though it was launched in 2024, the middle member of the Galaxy S24 series remains a stellar option for anyone who wants a fully loaded device that checks all the right boxes.
While that's great, the newest Galaxy S26 line-up has finally been unveiled, which means that the Galaxy S26 Plus is here. As expected, the latest mid-level flagship from Samsung packs a few upgrades that'll entice many prospective consumers, particularly those who've been thinking of upgrading from a previous-generation model.
But, in a world where annual device launches no longer matter as much as they once used to, does the freshest South Korean flagship live up to the hype? Let's see how the Samsung Galaxy S26 Plus vs. Galaxy S24 Plus compare and find out!
Samsung Galaxy S26 Plus vs. Galaxy S24 Plus: Design, display, and hardware
While Samsung's top-tier smartphones have had a consistent visual identity over the last few generations, things are finally changing with the Galaxy S26 series, as the newest trio comes with minor cosmetic updates instead of being a dull copy-and-paste job from the last year(s).
Samsung Galaxy S26 Plus sky blue
(Image credit: Derrek Lee / Android Central)
It appears the rumored CAD renders (via OnLeaks / Android Headlines) were on point, since the Galaxy S26 Plus (and the Galaxy S26) now feature their triple-lens rear camera systems stacked vertically inside a pill-shaped island, as opposed to the lenses being directly on the back panel like they are with the Galaxy 24 (and the Galaxy S25) devices. The same design update goes for the Galaxy S26 Ultra as well, although its fourth camera lens and laser AF module are still placed directly on the rear panel next to the island.
The visual refresh seems inspired by the Galaxy Z Fold 7 and the Galaxy S25 Edge, both of which have similar primary camera setups.
Samsung Galaxy S24 Plus
Flip over to the business end, and you're unlikely to find any changes. The Galaxy S26 Plus features a 6.7-inch Dynamic LTPO AMOLED panel with razor-thin bezels, super-high resolution, and a 120Hz adaptive refresh rate. It's the same screen that you'd find on the Galaxy S24 Plus, with vibrant colors and good brightness levels. However, with phones like the Motorola Razr Ultra 2025 having displays that can go up to a 165Hz, we can't help but feel Samsung could've done a bit better. You still get Gorilla Glass Victus 2 protection against scuffs and scratches, so that is a good thing.
Other than that, the Galaxy S26 Plus retains the boxy construction of the Galaxy S24 Plus (and the Galaxy S25 Plus), complete with flat aluminum side rails and an IP68 certification for dust and water resistance.
Swipe to scroll horizontally
Specifications
Category
Dimensions
158.4 x 75.8 x 7.3 mm (6.24 x 2.98 x 0.29 in)
158.5 x 75.9 x 7.7 mm (6.24 x 2.99 x 0.30 in)
Durability & Case Material(s)
IP68 rating for dust and water resistance, Corning Gorilla Glass Victus 2 (front and back), Aluminum frame
Weight
190 g
196 g
Display
6.7-inch Dynamic AMOLED (1440x3120 pixels resolution), LTPO, 120Hz variable refresh rate
Chipset / SoC
Qualcomm Snapdragon 8 Elite Gen 5 (for Galaxy) or Samsung Exynos 2600
Qualcomm Snapdragon 8 Gen 3
RAM
12GB
12GB
Storage
256GB/512GB
256GB/512GB
Sensors
Under-display ultrasonic fingerprint sensor, Accelerometer, Gyroscope, Proximity sensor, Compass, and Barometer
Wireless Connectivity
Wi-Fi 7, 5G (mmWave and Sub-6), Bluetooth 6.0, GPS, NFC, UWB, and USB-C 3.2 (with DisplayPort)
Wi-Fi 6e, 5G (mmWave and Sub-6), Bluetooth 5.3, GPS, NFC, UWB, and USB-C 3.2 (with DisplayPort)
Other Features
Samsung DeX (wired & wireless), Galaxy AI
Battery & Charging
4,900mAh (Li-Ion), 45W (wired) and 20W (wireless) charging, No Qi2 Support
4,900mAh (Li-Ion), 45W (wired) and 15W (wireless) charging, No Qi2 Support
Cameras (Rear)
50MP wide-angle, 10MP telephoto (3x optical zoom), 12MP ultrawide | 8K video recording
Camera (Front)
12MP wide-angle | 4K video recording
OS & Update Policy
Android 16 with One UI 8.5 (preinstalled), seven years of OS and security updates
Android 14 with One UI 6.1 (preinstalled), seven years of OS and security updates
The Galaxy S24 Plus is driven by a Snapdragon 8 Gen 3, which was Qualcomm's top-tier SoC back in 2024. Add to that 12GB of RAM and 256GB/512GB of internal storage, and it shouldn't be any surprise that Android Central's Derrek Lee came away impressed with the smartphone's performance (both general and gaming) when he reviewed it. As a matter of fact, this hardware still makes the Galaxy S24 Plus capable of going against some of the best Android phones out there.
Samsung Galaxy S26, S26 Plus, and S26 Ultra
Now, the Galaxy S26 Plus comes with the same 12GB of RAM and 256GB/512GB of internal storage. However, in the typical S-series fashion, the newest smartphone is powered by Qualcomm's latest top-of-the-line chipset, the Snapdragon 8 Elite Gen 5. In selected markets around the world, the Galaxy S26 Plus will be available with the Exynos 2600, Samsung's own newest flagship silicon.
Although we can't say anything about the smartphone's real-world performance until we test it out, it stands to reason that the Galaxy S26 Plus will perform better in comparison to the Galaxy S24 Plus, especially when it comes to resource-heavy workflows like on-device AI processing. However, you're unlikely to notice a huge difference as far as everyday tasks like gaming, web browsing, and streaming are concerned.
The Galaxy S26 Plus comes with all the modern connectivity and I/O options (e.g., Wired/Wireless DeX, NFC, and USB Type-C 3.2) that the Galaxy S24 Plus also has, albeit with some incremental enhancements here and there.
Samsung Galaxy S26 Plus vs. Galaxy S24 Plus: Cameras, software, and battery
The Galaxy S24 Plus features a triple-lens primary camera system having a 50MP primary sensor, a 10MP telephoto module (capable of 3x optical zoom), and a 12MP wide-angle unit. As you'd expect, 8K video recording and optical image stabilization are also included. It's a versatile setup that works quite well, with photos from all three lenses having plenty of resolved detail and incredible color reproduction. However, this hardware has also gotten a little long in the tooth at this point, having remained the same since the Galaxy S22 Plus.
The Galaxy S24 Plus lying face down on rocks
Sadly, Samsung seems to think otherwise, as the company has reused the same camera array on the Galaxy S26 Plus, yet again. While that's a little disappointing, improved processing should result in better photos and videos in comparison to what you get from the Galaxy S24 Plus, thus helping to make Samsung's newest Plus-sized model one of the best Android camera phones on the market. Even so, the older model still has it all to be your only all-purpose camera for everyday use.
Coming to software, the Galaxy S26 Plus (along with its siblings) runs One UI 8.5, the freshest version of its custom UI overlay, out of the box. Based on Android 16, the software has been out for a while and continues to get better, with the latest builds introducing Bixby updates and many other goodies. Apart from that, you can also expect improvements to Samsung's Galaxy AI suite, more customization options, and several other enhancements over time.
It goes without saying that most (if not all) of these features will be available for the Galaxy S24 Plus and other eligible devices in due course of time, all thanks to Samsung's industry-leading software support.
Samsung Galaxy S26 white
The Galaxy S24 Plus comes with a 4,900mAh battery that can effortlessly go a full day with moderate to heavy use. While some of the best budget Android phones do offer multi-day battery life, they also have less taxing hardware. The Galaxy S25 Plus managed to have an incredible endurance with the same exact battery size, and perhaps that's why Samsung decided to fit the new Galaxy S26 Plus with the same powerpack. We're expecting the phone to be able to last (at least) a full day, since the hardware is more power-efficient this time around. However, there's still no support for silicon-carbon tech, as Samsung refuses to get with the times and trails behind Chinese brands in adopting the new technology.
While the wired charging speed remains the same (45W) on both smartphones, you get slightly faster wireless charging on the Galaxy S26 Plus (20W) compared to the Galaxy S24 Plus (15W). As lackluster this "upgrade" is, perhaps what's even more disappointing is the lack of any integrated magnets for native Qi2 support. If you want that functionality, your only option is to get a magnetic case or go for an alternative flagship like the Google Pixel 10 Pro, which does support magnetic charging and a whole ecosystem of accessories.
Samsung Galaxy S26 Plus vs. Galaxy S24 Plus: Which should you go for?
Smartphones have matured to a level where buying the newest thing every year no longer makes any sense, and the Galaxy S26 Plus goes on to prove that. While it's true that it has a few upgrades (e.g., latest hardware, slightly quicker wireless charging), it's a still a rather incremental improvement over the Galaxy S24 Plus, a flagship that remains relevant despite being two years old at this point. You also have to consider the fact that the Galaxy S26 Plus has a starting price of $1,099.99 and will cost you quite a bit, even if you take advantage of pre-order deals. So, the question is, should you upgrade to the Galaxy S26 Plus from the Galaxy S24 Plus?
The Galaxy S24 Plus display, outside
Our suggestion is simple! If you absolutely need things like slightly faster wireless charging, better hardware, and perhaps most importantly, can get a good trade-in discount towards your Galaxy S24 Plus, by all means, go ahead and upgrade to the Galaxy S26 Plus. You'll be getting a feature-laden smartphone that'll last you for years to come.
Conversely, if you're not obsessed with having the newest thing out there, don't care much about incremental overhauls, and your Galaxy S24 Plus already does everything that you need it to do, upgrading to the Galaxy S26 Plus just for the sake of it makes no sense. Hold on to the phone that you already have, as it's still going to be supported for a very long time. Unsurprisingly, the Galaxy S26 Plus is not that much of an improvement over the Galaxy S25 Plus either, so you can go for that last-gen model if you really must upgrade.
Rajat Sharma
Contributor
When Rajat got his first Personal Computer—a Pentium III machine with 128MB of RAM and a 56kbps dial-up modem—back in 2001, he had little idea it would mark the beginning of a lifelong love affair with gadgets. That fascination, combined with a penchant for writing and editing, ultimately led to him becoming a technology journalist. Some of his other interests include Photography, Hand Lettering, and Digital Typography. Rajat is also somewhat obsessed with wrist-worn timepieces and appreciates a Casio just as much as a Jaeger-LeCoultre.
