iPhone Air vs. Samsung Galaxy S25 Edge: Which thin flagship prevails?
Thin phones are in, and the iPhone Air and the Samsung Galaxy S25 Edge are going to be the top options for ultra-slim flagships heading into 2025. I bought a Galaxy S25 Edge with my own cash and plan to do the same with the iPhone Air, and in this guide, I'll help you figure out how these two smartphones compare.
For those who don't quite understand the appeal of thin phones, here's a quick overview. There are certainly some people who use every percentage of their phone's battery life each day and all of its features. However, there's also a subset of users that don't need extremely long battery life or a pro-grade camera system. For them, it's arguably better to carry a thin and light phone daily, and add separate tools like a MagSafe/Qi2 battery pack or a dedicated camera when they're really needed.
If that sounds like you, an iPhone Air or Galaxy S25 Edge might be the change you need. I ditched heavy and thick flagships this year and haven't looked back. But you'll want to pick the right one — here's how to decide.
iPhone Air vs. Samsung Galaxy S25 Edge: Design and display
The iPhone 17 Air in press renders in all colors.
(Image credit: Apple)
Smartphone manufacturers have been cheating on thinness for ages with camera bumps and creative math — there isn't a single brand that includes the thickness of the camera bump in their official measurements, and foldable phones even omit the size of the internal bezel when talking about their unfolded measurements.
However, the iPhone Air takes this practice to the extreme. It doesn't have a camera bump; it has a camera plateau, and it practically houses the entire phone — the rest of the chassis is filled almost entirely with battery. This strategy makes the iPhone Air feel impossibly thin, with much of the body measuring only 5.6mm thick. At the same time, the plateau will protrude further off the back of the phone than the Galaxy S25 Edge.
By comparison, Samsung made the Galaxy S25 Edge measure 5.8mm thick. The difference of 0.2mm in thickness might sound minuscule, but early first impressions from those who have held the Air seem to show it's a difference you can feel, which may be attributed to its curvier chassis.
The front of the Samsung Galaxy S25 Edge.
(Image credit: Brady Snyder / Android Central)
There's a big difference in screen size and overall form factor between the iPhone Air and Samsung Galaxy S25 Edge. The former has a 6.5-inch screen, which slots in between what would typically be a base or a plus-sized phone. Meanwhile, the Galaxy S25 Edge has a 6.7-inch display that's identical in size to the Galaxy S25 Plus. Both phones are using AMOLED screens with 120Hz LTPO support, but the iPhone is slightly brighter, topping out at 3,000 nits.
It's worth noting that due to all the components in the iPhone Air camera plateau, Apple had to shift the Dynamic Island and Face ID sensors down to make everything fit. This means the pill-shaped camera cutout will cut deeper into the iPhone Air display, obstructing more of your content. The Galaxy S25 Edge has a hole-punch camera cutout in the display that's much more minimal than what the iPhone Air offers.
The iPhone Air also has an anti-reflective coating similar to that of the Samsung Galaxy S25 Ultra. Both phones use a titanium construction for durability and feature IP68 certification against dust and water ingress.
Personally, I'm torn on which phone looks better. To me, the reasonably small rear camera bump is a huge appeal of the Galaxy S25 Edge, but it's hard not to be impressed by the 5.6mm thickness of the iPhone Air.
iPhone Air vs. Samsung Galaxy S25 Edge: Hardware and specs
The iPhone Air and Galaxy S25 Edge both impressively retain similar performance to that of their "Pro" and "Ultra" counterparts. Apple put the A19 Pro chipset in the iPhone Air, but it is technically a binned version of the system-on-a-chip with one fewer GPU core. For what it's worth, the Galaxy S25 Edge has the exact same Snapdragon 8 Elite for Galaxy processor as its predecessors with identical core counts.
Both phones sport 12GB of memory. You can get the iPhone Air in up to 1TB of storage, while the Galaxy S25 Edge is capped at 512GB.
The iPhone Air is powered entirely by Apple chips, including the Apple C1X modem for cellular and Apple N1 for general connectivity. It supports Wi-Fi 7, Bluetooth 6, and Thread, but crucially, the Apple C1X only supports standard 5G — there's no mmWave support like the Galaxy S25 Edge.
Swipe to scroll horizontally
Specs
Category
iPhone Air
OS
iOS 26 (five OS upgrades guaranteed)
One UI 7 (up to seven OS upgrades)
Display
6.5‑inch (diagonal) all‑screen OLED display, 120Hz LTPO, 3,000 nits peak brightness
6.7-inch QHD+
Dynamic AMOLED 2X, 120Hz LTPO
2,600 nits peak brightness
Processor
Apple A19 Pro
RAM
12GB
12GB
Storage
256GB, 512GB, 1TB
256GB, 512GB
Rear Camera 1
48MP Fusion primary, 26 mm, ƒ/1.6 aperture, sensor-shift optical image stabilization
2x optical-quality zoom
200MP wide, f/1.7, 24mm, OIS, PDAF, 0.6µm
Rear Camera 2
N/A
12MP ultrawide, f/2.2, 13mm, PDAF, 1.4µm
Selfie Camera
18MP Center Stage camera
ƒ/1.9 aperture
Autofocus with Focus Pixels
12MP, f/2.2, 26mm, PDAF
Audio
Earpiece speaker
Stereo speakers
Connectivity
Wi-Fi 7, Bluetooth 6, Thread, NFC, 5G, MagSafe, USB-C (2.0)
Wi-Fi 7, Bluetooth 5.4, NFC, 5G, USB-C (3.2)
Protection
IP68
IP68
Battery
3,149mAh (per EU filings)
3,900mAh
Charging
20W wired and MagSafe/Qi2; 0% to 50% in 30 minutes
25W
Dimensions
156.2 x 74.7 x 5.64mm
158.2 x 75.6 x 5.8mm
Weight
165g
163g
Colors
Space Black, Cloud White, Light Gold, Sky Blue
Titanium Icyblue, Titanium Silver, Titanium Jetblack
The iPhone Air has a major advantage in supporting MagSafe and Qi2 with no external cases or accessories required. This will make topping up the relatively small 3,149mAh battery easy with chargers like the official MagSafe battery pack or third-party options. Samsung didn't include Qi2 magnets on the Galaxy S25 Edge, so you'll need a case and a battery pack to magnetically recharge the 3,900mAh battery.
The Samsung Galaxy S25 Edge with an Anker MagSafe battery pack attached.
There are a few other iPhone Air hardware limitations to point out: there's no bottom speaker, and the USB-C port is only USB 2.0. The Samsung Galaxy S25 doesn't have either drawback, with stereo speakers and a USB 3.2 Gen 1 port.
iPhone Air vs. Samsung Galaxy S25 Edge: Cameras
Dual cameras on the Galaxy S25 Edge
(Image credit: Nirave Gondhia)
The iPhone Air has one rear camera on the back — it's a 48MP sensor that Apple claims to effectively be two cameras, as it supports 2x optical-quality zoom. By that logic, the Samsung Galaxy S25 Edge effectively has three cameras. The Galaxy S25 Edge's main camera is a 200MP sensor that can also provide 2x optical-quality zoom via a technique called sensor cropping. On top of that, the Samsung phone has a 12MP ultrawide camera for wide shots.
Apple's 18MP front-facing camera on the iPhone Air is impressive. It features a square sensor that enables horizontal and portrait selfies without physically rotating the device. Samsung doesn't have this feature on the Galaxy S25 Edge; its front-facing camera is the usual 4:3 aspect ratio. The 12MP, f/2.2 sensor is still solid and can produce great photos.
iPhone Air vs. Samsung Galaxy S25 Edge: Which should you buy?
The look and feel of the Samsung Galaxy S25 Edge is downright mind-blowing, and there appear to be fewer compromises than the iPhone Air. Compared to Apple's thin handset, the Galaxy S25 Edge has a flagship processor without binning, a faster USB-C port, stereo speakers, a rear ultrawide camera, a larger display, and a smaller front-facing camera cutout. However, it's slightly thicker and more expensive than the iPhone Air.
There's just one reason why it's extremely difficult to recommend the Galaxy S25 Edge over the iPhone Air. The former doesn't have Qi2 magnets onboard, and this feels like a mandatory feature for thin phones with shorter battery life. The iPhone Air, having MagSafe and Qi2 support, means you can quickly and easily top up the phone with a battery pack in a pinch. It'll be much tougher to do so on the Galaxy S25 Edge without a case, and adding a case somewhat defeats the point of a thin phone.
Otherwise, the choice might come down to whether you prefer iOS 26 or One UI 7. Neither phone is perfect, but both the iPhone Air and Galaxy S25 Edge are a breath of fresh air for people disenfranchised by thick, heavy smartphones.
TOPICS
Brady Snyder
Contributor
Brady is a former contributor for Android Central, who wrote for the site from 2023 to 2026. With a focus on news, phones, and audio, he spent years reporting and commenting on all things related to consumer technology.
Brady reviewed Apple, Google, Samsung, and Motorola phones for Android Central, and attended industry-wide events like IFA and MWC on behalf of the publication. He holds a bachelor's degree in journalism from St. John's University.
His work has been published in XDA, Android Police, Android Authority, MakeUseOf, and SoundGuys, among other sites. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
