Meet the TOP 12 best Pixelsnap and Qi2 accessories for the Google Pixel 11
It's time to get your Pixel 11 all decked out with the best magnetic accessories.
As a fan of all things MagSafe and Qi2, I have tried and tested dozens and dozens of gadgets in my quest to find the best Pixelsnap and Qi2 accessories for the Pixel 11. Beyond the most basic items like wireless chargers and power banks, there is so much more to discover. Things like lights, tripods, and even suction cup mounts come with magnets and enhance your Google Pixel 11's photography and videography.
Some of these picks might feel predictable, such as the legendary MagSafe PopSockets PopGrip. Others, like the fantastic KraftGeek GlowRing Foldable Ring Light may come as a surprise. Keep reading to find all the best Pixelsnap and Qi2 accessories available for the Pixel 11 right now.
The best Pixelsnap and Qi2 accessories for the Google Pixel 11
Best charging stand
The Pixel 11 series supports 25W wireless charging across the board, but only with compatible chargers. This is why the first-party Google Pixelsnap Charger with Stand is perfect for your Pixel 11. Plus, you can detach the charger from the stand if you like.
Best tripod
KraftGeek took the best phone tripod I have ever used and somehow made it even better. The GlowRing Foldable Ring Light with Built-in Battery comes with the fantastic JustTap tripod as well as a foldable, 5,000mAh ring light and has a rotating MagSafe phone mount in the center. A USB-C charging cable is also provided.
Best computer mount
Using your Pixel 11 as a webcam for your computer? Get the versatile Rolling Square Edge Pro Core, which is a magnetic mount for computers and tablets. Made of solid metal, it is very secure and sturdy, has powerful N52 magnets, and tilts on a hinge.
Best car charger
There are barely any car chargers that deliver 25W wireless charging to a Pixel 11. The iOttie Velox Pro Qi2.2 25W Fast Charging Magnetic Wireless Car Charger is one of the few such accessories that is certified by Google to deliver the full 25W speed.
Best selfie light
ULANZI specializes in affordable photography and videography equipment for phones and cameras. The Ulanzi LM19 MagSafe LED Selfie Ring Light costs just $25, has adjustable brightness and temperature, is magnetic, and acts as a stand in a pinch.
Best SSD
The Orico MagPro Portable SSD A20PLUS has a tiny footprint. You get a USB 3.2 Gen 2 Type-C connector with a compatible cable included, delivering 20Gbps data transfer speeds. It's a great way to add 512GB, 1TB, or 2TB of storage to your Pixel 11.
Best suction mount
There are so many variations of this magnetic suction cup mount, but the branded ones like CASETiFY and BURGA cost an arm and a leg. This cheap alternative from amBand works just as well for just $10 and comes in 11 assorted colors.
What does Qi2 support mean?
Qi2 is essentially a type of magnetic technology that's primarily designed for wireless charging and it is built on the MagSafe standard. Apple devices have had Qi2 (or MagSafe) support for years, but the technology has only recently begun to be added to mainstream Android phones (although Google calls its version Pixelsnap).
In addition to simple wireless charging, Qi2 support also gives you the ability to use a bunch of new magnetic accessories with your phone, from grips and ring lights to tripods and portable power banks.
What is Google Pixelsnap?
Pixelsnap is simply Google's name for the Qi2 magnetic technology built into the Google Pixel 10 and Pixel 11 series. Just like the best MagSafe accessories, Pixelsnap accessories include wireless chargers, phone mounts, ring lights, and so much more.
What Qi2 accessories should I buy for my Pixel 11?
The first accessory anyone should buy for a new smartphone is always a phone case. You can't go wrong with any of CASETiFY's spectacular MagSafe cases for the Pixel 11 series. They come in varying levels of drop-proofing and can be customized to another level. Whether you want to create your own design, add a ring stand to the camera bar, or change the color of the magnetic ring or bumper frame, CASETiFY lets you do it all. Plus, the brand always has hundreds of cool patterns, designs, artwork, and collabs to choose from. Some of my personal favorites include the Bridgerton and Jujutsu Kaisen collections.
Phone grips are some of the most basic magnetic accessories, but I find them to be necessary. A decent magnetic grip can easily prevent falls and relieve your fingers of repeated stress from holding your phone too long and too frequently. The best part of a magnetic grip is that there's no sticky adhesive — you can pop the grip on and off at any given time. PopSockets is the king of the hill when it comes to affordable, long-lasting phone grips.
It would be a crime to not make the most of the wonderful cameras on the Google Pixel 11 series. The KraftGeek GlowRing Foldable Ring Light with Built-in Battery is an awesome ring light and tripod kit and it is a match made in heaven for the Pixel 11. The ring light is foldable, has a magnetic rotating mount in the center, and has adjustable brightness and temperature. It is also wireless and has a gigantic 5,000mAh capacity, with a USB-C charging cable and an adhesive magnetic ring provided with the kit. The tripod is none other than the outstanding KraftGeek JustTap, which unfolds the legs in a simple tap. It's also incredibly lightweight yet sturdy, and gets as tall as 66 inches or as compact as 13 inches.
How can I use magnetic accessories for Pixel 11 photos and videography?
Converting your Pixel 11 into a mobile photography or videography rig might sound expensive and intimidating, but Qi2 greatly simplifies things. I have used countless gimbals, tripods, and phone stands over the years, and I hate fumbling with the adjustable arms the most. Clamping your phone into a traditional stand or tripod is super annoying, especially when your phone case is on the thicker side. Luckily, the KraftGeek GlowRing Foldable Ring Light with Built-in Battery has a magnetic mount.
The KraftGeek GlowRing is an ingenious way to make the most of your Google Pixel 11's magnetic prowess. All you have to do is slap your phone onto the magnetic mount and set the tripod up — which, by the way, also takes a few short seconds thanks to the "tap to unfold" base mechanism. This tripod is also unbelievably compact and lightweight, with a level of stability and sturdiness that you would not expect from something this light.
I highly recommend getting a separate magnetic light for your Google Pixel 11's cameras as well, because it's not always feasible to travel with a full-sized ring light. The Ulanzi LM19 Selfie Ring Light is incredibly small, but still performs exceedingly well. It has several levels of brightness and temperature adjustability, charges via USB-C, and can be tilted thanks to the way it is built. It's a fantastic tool to boost your Pixel 11's photography game.
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
- Patrick Farmer eCommerce Editor
