Baseus just rolled out the best 5,000mAh Qi 2 power bank
Baseus PicoGo AM31 5000mAh Power Bank testing on Android Central
(Image credit: Apoorva Bhardwaj / Android Central)
Disclaimer
Enjoy our content? Make sure to set Android Central as a preferred source in Google Search so you can stay up-to-date on the latest news, reviews, features, and more.
Baseus always delivered good charging products, but the Chinese manufacturer is taking things to a whole new level in 2025. The brand rolled out dozens of new products, including power banks and car chargers with retractable cables, GaN chargers, and so much more.
What stood out the most is the Qi 2 power bank; I tested the standard PicoGo models earlier in the year, and liked the diminutive size and sturdy build quality. While there's no shortage of magnetic power banks at the moment, the PicoGo is among the thinnest around, and it has Qi 2 integration, making it a standout choice.
Baseus now has an updated model dubbed the PicoGo AM31; this variant is available in 5,000mAh, and it gets Qi 2 as well as a kickstand at the back. The PicoGo AM31 is available on Amazon for just $39, putting it in line with other magnetic power banks I used recently.
At just 136g, the PicoGo AM31 doesn't weigh much at all, and it is thinner than most phones, making it highly portable. The curved design is a nice touch, and it makes holding the power bank that much easier. It's available in four colors as well, giving you the ability to accessorize with your phone.
It has a metal chassis that makes it durable, and I didn't notice any issues with build quality in the two months I used it. The kickstand at the back is an exciting addition, and it enables the use of StandBy mode when you're using it with an iPhone.
I tested the PicoGo AM31 with my Pixel 10 Pro XL and iPhone 16 Pro Max, and it did a great job charging both devices. It hits 15W over the Qi 2 protocol, and there's a USB-C cable on the side that goes up to 20W. It has a strong magnetic connection, and I didn't see any problems while using the power bank outdoors.
There are tiny LED lights at the back that indicate battery life, and a power button at the bottom. The main difference between the 5,000mAh PicoGo AM31 and the standard model is that it gets Qi 2 integration; if that's something you need, then I highly recommend getting the AM31. The built-in kickstand also makes it easy to interact with your phone while it's charging, but if you don't need it, the regular PicoGo can be bought at $22, a downright bargain.
Harish Jonnalagadda
Senior Editor - Mobile
