I compared the best universal Bluetooth trackers on the market from Chipolo and Pebblebee to see how they compare to the industry standard. The result may surprise you
Pebblebee and Chipolo's universal Bluetooth trackers for Android and iOS
(Image credit: Namerah Saud Fatmi / Android Central)
Gadget Weekly
Inspector Lloyd
Join Namerah Saud Fatmi as she explores the cool, quirky, and sometimes downright odd world of smartphone accessories, gadgets, and other nerdy toys every week.
Until 2024, Bluetooth trackers were only compatible with either Google's or Apple's Find My Device network. However, a new range of universal trackers is now widely available, allowing users to pair them with both Android and iOS devices. Tile, Chipolo, and Pebblebee are at the forefront of this innovation. While Tile by Life360 is more widely known, you may or may not be as familiar with the latter names.
I'm here to tell you that both Chipolo and Pebblebee have amazing trackers. Today, I'll be focusing on universal trackers that are rechargeable and how they perform compared to Tile by Life360 trackers, which set the industry standard.
Disclaimer
Enjoy our content? Make sure to set Android Central as a preferred source in Google Search, and find out why you should so that you can stay up-to-date on the latest news, reviews, features, and more.
Trackers that can hang on keychains
Bluetooth trackers come in a few form factors. The most popular shape is a circular chip, featuring a hole or loop that allows for attachment to a key ring. Since they're so small and lightweight, you can even attach them to pet collars, though most brands don't advertise them as such for legal reasons.
Chipolo's keychain attachment is called the LOOP, whereas Pebblebee's take on it is called the Clip. They compete directly with the Tile by Life360 Pro (2024). I use all of these brands regularly and can say that their loudness levels are more or less the same, which is why I did not mention volume levels in my comparison.
Swipe to scroll horizontally
Category
Chipolo LOOP (2025)
Pebblebee Clip Universal (2024)
Range
400ft / 120m
500ft / 150m
500ft / 150m
Water and dust resistance
IP67
IPX6
IP68
Battery
6 months, rechargeable via USB-C
1 year, rechargeable via USB-C
1 year, replaceable CR2032 cell
Dimensions
 40 x 57 x 8 mm
45 x 38 x 8.50 mm
59 x 34 x 7.7 mm
Price
$39
$34.99
$34.99
The Chipolo LOOP has a superior IP rating compared to the Pebblebee Clip Universal, but it's also more expensive. Other than that, Pebblebee has the upper hand in this arena. Both charge via USB-C, but Chipolo lasts for six months on a single charge, whereas Pebblebee delivers twice as much — a whole year. Pebblebee also has a better Bluetooth range, 500 feet, as opposed to Chipolo's 400-foot range.
Meanwhile, the Tile by Life360 Pro (2024) costs the same as Pebblebee's Clip and has the same range, but it has a far more heavy-duty IP68 water and dust-proof rating. Although the Tile Pro lasts for a year too, it doesn't recharge. Instead, you need to replace the CR2032 battery when it dies.
Sleek trackers for your wallet
The second most commonly preferred type of Bluetooth tracker is a wallet tracker. These are shaped like credit cards and can be just as slim, depending on which brand you buy from.
Chipolo's CARD stands out because not only is it rechargeable, but it features magnetic Qi wireless charging (not Qi2, just plain old Qi). I interviewed the company's co-founder and CDO about this clever contraption in detail, which you can read here if you're interested.
Category
Chipolo CARD (2025)
Pebblebee Card Universal (2024)
Tile by Life360 Slim (2024)
Range
400ft / 120m
500ft / 150m
350ft / 100m
IP67
IPX6
IP68
Battery
6 months, rechargeable via Qi wireless charging
1.5 years, rechargeable via proprietary magnetic USB-C cable
3 years, non-replaceable
Dimensions
85.2 x 53.6 x 2.5 mm
85 x 54 x 2.8 mm
85.4 x 53.9 x 2.5 mm
Price
$39
$34.99
$29.98
Google Fast Pair makes setting up instantaneous
It's so disappointing to see that Tile couldn't figure out a way to make its card-shaped tracker rechargeable. It'll need to be disposed of after three years, meaning you'll end up buying another one and spending far more money in the long run.
Pebblebee's Card is rechargeable, but you need to use a special magnetic charging cable with a Type-C port on one end. If you lose the cable, you're done for.
Meanwhile, Chipolo's pricier CARD recharges via any Qi, Qi2, or MagSafe wireless charger. It's awesome because it's so versatile and not proprietary, so you don't have to worry about losing the cable. Despite this, it's just as thin as the Tile Slim!
Setting up the universal trackers from Chipolo and Pebblebee is incredibly quick and easy, thanks to Google Fast Pair and Find Hub. Before you have time to process what's happening, everything sets up. You don't even need the dedicated brands' apps on your phone. Both Chipolo and Pebblebee's universal trackers are added to the Google Find Hub, and you can manage them from there.
All three brands' trackers can be used as is without purchasing a monthly subscription; however, you may not be able to make the most of them at times. Life360 offers a free membership tier, but to enjoy the best features of your Tile tracker, such as live location sharing, you must be on a paid plan for $14.99/month or $24.99/month. Chipolo has no premium plans, giving you all the features for free within the app. Pebblebee has an Alert Live subscription that costs just $2.99/month or $24.99/year for live GPS location updates and alerts.
If you're willing to pay a premium for more than just Bluetooth tracking, Pebblebee's plan is worth the splurge.
Which Bluetooth tracker should you opt for?
Pebblebee's universal Bluetooth tracker for Android and iOS
When buying a Bluetooth tracker intended for use on a keychain, I'd say it depends on where you live. If you're in a tropical region subject to constant rainfall, it's probably best to opt for something with robust waterproofing. This would give Tile by Life360 the edge over the rest, but the Tile Pro's replaceable cell is cumbersome.
I recommend getting the Pebblebee Clip Universal instead. It's the whole package for the cheapest price among the three. You get IPX6 water resistance, a USB-C cable for charging, and a year-long battery life. I myself use the Clip on my car key fob. Pebblebee includes a sturdy key ring, which is a nice bonus.
When it comes to wallet trackers, the Chipolo CARD is the reigning champion. Tile's entry doesn't even recharge; you'll have to toss it after three years, creating e-waste. Meanwhile, the Chipolo CARD recharges wirelessly, so you don't have to worry about having your proprietary cable around like the Pebblebee Card requires. For about $4 more, you get magnetic Qi wireless charging and a vastly superior IP rating, so it's the one you should pick.
FAQ
What makes Bluetooth trackers from Chipolo and Pebblebee "universal"?
They are "universal" because they are compatible with both Google's Find My Device network (for Android) and Apple's Find My network (for iOS), allowing users to track their items regardless of which mobile operating system they use.
Do the Chipolo and Pebblebee trackers use replaceable or rechargeable batteries?
Unlike some competitors, both Chipolo and Pebblebee offer rechargeable trackers. The clip-style trackers (Chipolo LOOP and Pebblebee Clip) charge via USB-C, while the Chipolo CARD uses magnetic Qi wireless charging, and the Pebblebee Card requires a proprietary magnetic USB-C cable.
Which card-style tracker is better for wallet use: the Chipolo CARD or the Pebblebee Card?
The Chipolo CARD is generally considered the superior option for wallets. It's significantly thinner (2.5 mm) compared to the Pebblebee Card (14 mm) and offers the versatility of magnetic Qi wireless charging, meaning you don't have to worry about losing a proprietary cable.
Are subscriptions required for these Bluetooth trackers?
While the trackers can be used without a subscription, some advanced features may require a monthly fee.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
