Belkin Stage PowerGrip vs. KraftGeek PowerShutter: Convert your smartphone into an old-school camera with these new-school power banks. They both have their charms, but one has an advantage over the other
Belkin Stage PowerGrip and KraftGeek PowerShutter power bank stands
(Image credit: Namerah Saud Fatmi / Android Central)
Gadget Weekly
Inspector Lloyd
Join Namerah Saud Fatmi as she explores the cool, quirky, and sometimes downright odd world of smartphone accessories, gadgets, and other nerdy toys every week.
The Belkin Stage PowerGrip and KraftGeek PowerShutter are a new breed of power banks — the kind that convert your smartphone into an old-school camera, in a sense.
I love this new era of power banks where the sky's the limit, and brands are playing around with form factors. From high-capacity power banks to transparent ones, we've seen those that come with cooling fans, and even some that double as SSDs.
Now, smartphone accessory brands like KraftGeek and Belkin are rethinking the form factor once again with their portable power banks that have MagSafe support, Bluetooth camera buttons, and act as phone stands.
Disclaimer
Enjoy our content? Make sure to set Android Central as a preferred source in Google Search, and find out why you should so that you can stay up-to-date on the latest news, reviews, features, and more.
Belkin and KraftGeek's magnetic power bank stands share the same core
There are some differences between the two power banks, but the most vital one is the price. The Belkin Stage PowerGrip costs $79.99, whereas the much more affordable KraftGeek PowerShutter costs $36.99. KraftGeek's offering is less than half the price of the Belkin option.
The Belkin Stage PowerGrip has a much larger capacity, giving you 9,300mAh, but it's also 67 grams heavier. In comparison, the KraftGeek PowerShutter has a modest 5,000mAh capacity.
Swipe to scroll horizontally
Belkin Stage PowerGrip vs KraftGeek PowerShutter
Category
Price
$79.99
$36.99
Capacity
9,300mAh
5,000mAh
Charging
15W wired, 15W wireless
18W wired, 10W wireless
Charging indicator
Display
LED lights
Connectivity
Bluetooth
Bluetooth
Buttons
Power button, shutter button
Ports
USB-C port, built-in USB-C cable, 1/4 inch camera hole, lanyard holes
USB-C port, 1/4 inch camera hole
Dimensions
4.6 x 3.3 x 1.6 inches
4.75 x 1.875 x 3.25 inches
Weight
271 grams
204 grams
Colors
Charcoal, Ice Blue, Sand
Black, White
Both the Belkin Stage PowerGrip and KraftGeek PowerShutter have magnetic pads where you can mount any MagSafe or magnetic Qi2 phone. You can also use both accessories as phone holders, allowing you to use your device in both portrait and landscape orientations.
You can pair your phone with either power bank stand using Bluetooth, enabling you to use the camera shutter button to take pictures. It's a very comfortable method of shooting pictures and videos, especially if you grew up with digital cameras and DSLRs.
Thanks to the 1/4-inch threaded hole, you can mount your phone on any standard tripod. This eliminates the need to buy a separate stand or stand mount just for your phone.
How does Belkin justify that price gap?
At $79.99, the Belkin Stage PowerGrip costs twice as much as the KraftGeek PowerShutter. Besides the extra battery backup, you also get more color options, a built-in USB-C cable, lanyard holes, and an LED display indicating the battery level and connection status.
Belkin's camera stand also has better functionality. You can switch between photo and video modes on your phone with the shutter button. On top of that, you can disable wireless charging so the Belkin Stage PowerGrip isn't unnecessarily draining its battery when in use.
With KraftGeek, you get what you pay for
When it comes to KraftGeek's option, you cannot turn off the wireless charging feature, so it's constantly recharging your phone wirelessly when in use. This, paired with the smaller battery, means that it drains much faster than Belkin's power bank stand.
Additionally, you cannot use the shutter button to switch between photo and video modes on the KraftGeek PowerShutter.
You do, however, get extras in the box that compensate for these drawbacks. There's a USB-C charging cable and a magnetic adapter ring provided.
Recharging the KraftGeek PowerShutter takes a while because of the 18W wired charging speed. However, it's still faster than Belkin's slower 15W wired charging speed.
KraftGeek gets my vote when it comes to comfort. It is noticeably lighter, and I prefer its slightly softer faux leather grip.
Belkin Stage PowerGrip vs KraftGeek PowerShutter: Which should you buy?
Performance-wise, the Belkin Stage PowerGrip lasts much longer than the KraftGeek PowerShutter, giving it a major edge over it. The extended battery life alone is worth the splurge. It's perfect for vacations and trips where you need to take lots of pictures and videos but have battery anxiety.
Additionally, since you can turn the wireless charging off on the Belkin camera stand power bank, it also helps you conserve its power instead of wasting it unnecessarily. The built-in Type-C cable can get awkward to use, but it's so convenient to have. You don't have to worry about packing a separate cable.
At $36.99, the KraftGeek PowerShutter is an absolute steal. It's a fantastic alternative to the more premium Belkin Stage PowerGrip. However, if you can afford to spend another $43, the $79.99 Belkin option will make you a lot happier!
Bonus tip: If you really want the Belkin Stage PowerGrip but are counting the change you found in your couch, just wait for Black Friday to grab a good deal on it.
FAQ
How do these power banks connect to your smartphone?
The Stage PowerGrip and PowerShutter physically connect to smartphones using magnets, for MagSafe/Qi2-compatible phones or cases. They connect to your phone's software via Bluetooth.
How fast are the wireless charging speeds?
The Belkin Stage PowerGrip supports 15W wireless charging output, while the KraftGeek PowerShutter only supports 10W wireless charging output.
Can you turn the wireless charging on and off?
Only the Belkin Stage PowerGrip allows users to turn the charging functionality on or off, while the KraftGeek PowerShutter will continuously charge your device.
Is the Belkin Stage PowerGrip worth the higher price?
The Stage PowerGrip is priced higher than the PowerShutter likely due to the larger battery, built-in USB-C cable, and additional functionality that you won't find on the cheaper model. However, the PowerShutter is still a great value for anyone looking for a power bank that doubles as a phone grip/camera shutter.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
