Samsung Galaxy XR vs. Apple Vision Pro: Battle of the premium headsets
The Android XR era is officially here with the debut of Samsung Galaxy XR, the company's first headset developed in collaboration with Google. It's the natural rival to Apple Vision Pro, the innovative, but generally unsuccessful, VR headset priced at a whopping $3,500. It looks like Samsung used Vision Pro as a baseline for Galaxy XR — the headset nearly matches Apple's offering spec-for-spec, even besting it in some categories.
Samsung priced the Galaxy XR at $1,800, almost exactly half the price of the Vision Pro. Naturally, that makes the Samsung Galaxy XR a bit easier for tech enthusiasts to justify. Both are still firmly early-adopter products, regardless, but which one is best? Let's compare all the features and differences between Galaxy XR and Vision Pro.
Samsung Galaxy XR vs. Apple Vision Pro: Design and displays
A photo of Samsung Galaxy XR sitting on a pedestal from a top-down, right-side angle.
(Image credit: Samsung)
Samsung took notes from the VR headsets that predated the Galaxy XR, and it paid off. Instead of trying to copy one headset, the company picked the best features from Meta Quest Pro and Apple Vision Pro in designing Galaxy XR. The end result is a headset with a striking appearance and the ability to be used with or without light blockers.
By comparison, Vision Pro is designed to be used with its light seal all the time. There are no first-party options for Vision Pro open facial interfaces. If you get creative, third-party accessories and 3D print files can fill the gap. Either way, Vision Pro isn't designed to be used without light seals like Galaxy XR.
Apple Vision Pro outdoors on a table with accessories.
(Image credit: Brady Snyder / Android Central)
Vision Pro uses a cloth strap, and there are multiple first and third-party straps available. Samsung took a different approach with Galaxy XR, using a rigid strap for better weight distribution and stability.
Apple may have solved its cloth strap issues with a new Dual Knit Band with counterweights for stability, but Samsung's strap design has other benefits. It houses a USB-C port separate from the battery connector for accessory connection.
A photo of the Samsung Galaxy XR headset sitting upside down, emphasizing the lenses and forehead padding.
(Image credit: Michael Hicks / Android Central)
Both Apple Vision Pro and Samsung Galaxy XR have impressive, industry-leading micro-OLED displays. Samsung has a slight edge in quality, with a 3,552 x 3,840 resolution and 96% coverage of the DCI-P3 color gamut.
Apple still offers a resolution of 4K per eye, but only 23 million pixels, compared to Samsung's 29 million. Vision Pro does have the edge in refresh rate, with the latest model topping out at 120Hz. Galaxy XR can only hit 90Hz, and the default setting is 72Hz.
Each headset supports prescription lens inserts for people with vision correction needs. There are no official hardware controllers for Vision Pro, but PlayStation VR controllers are fully supported. Samsung does make controllers for Galaxy XR, although they're sold separately.
Samsung Galaxy XR vs. Apple Vision Pro: Hardware and specs
While Samsung has the clear edge in design and displays, Apple has an advantage in performance. The original Vision Pro was a solid performer with the M2 chip, but the latest Apple M5 revision is even better. It adds 120Hz support, hardware-accelerated ray tracing and mesh shading, and better rendering.
In other words, Vision Pro will deliver crisper images with M5 despite using the same display hardware. The headset also uses an Apple R1 co-processor specialized for taking in and processing data from the headset's wide assortment of cameras and sensors.
Meanwhile, the Samsung Galaxy XR is powered by Qualcomm's Snapdragon XR2 Plus Gen 2 processor. It's still a very good chip, bringing a 20% higher CPU frequency and 15% higher GPU frequency than the Snapdragon XR2 Gen 2. The latter powers the Meta Quest 3 and Quest 3S, but the more powerful variant is key to running Galaxy XR smoothly.
Swipe to scroll horizontally
Specs
Category
Samsung Galaxy XR
Apple Vision Pro
Processor
Snapdragon XR2+ Gen 2
Apple M5 (or Apple M2)
Memory
16GB RAM; 256GB storage
Up to 1TB storage
Display
3,552 x 3,840, 29 million pixels Micro-OLED; 96% DCI-P3
3,660 × 3,200, 23 million pixels, Micro-OLED, 92% DCI-P3
Refresh rate
60Hz, 72Hz (default), 90Hz
90Hz, 96Hz, 100Hz, or 120Hz
Field of view
109ºH; 100ºV
~100º
Camera
6.5MP; 18mm/ F2.0
Row 5 - Cell 2
Sensors
Two passthrough cameras; six world-facing tracking cameras; four eye-tracking cameras; five IMUs; one depth sensor; one flicker sensor
Two high-resolution main cameras (for passthrough); Six tracking cameras on the sides and bottoms (for hand tracking); Four internal tracking cameras (for eye tracking); LiDAR scanner and TrueDepth camera (for depth perception); Four inertial measurement units (IMUs); Flicker sensor; Ambient light sensor
Mics & speakers
Six-mic array with beamforming; two dual speakers (Woofer + Tweeter)
Six-mic array with directional beam forming; Dual-driver audio pods
Audio codecs
MP3, AMR-NB/WB, AAC/ AAC+/ eAAC+, Vorbis, FLAC, Opus, Dolby Digital (Plus, Atmos)
AAC, MP3, Apple Lossless, FLAC, Dolby Digital, Dolby Digital Plus, and Dolby Atmos
Video
Resolution: UDH 8K (7,680 x 4,320) @ 60FPS
Codecs: H.263, H.264, HEVC, MV-HEVC, MPEG-4, VC-1, VP8, VP9, AV1
Codecs: HEVC, MV‑HEVC, H.264, AV1, HDR with Dolby Vision, HDR10, and HLG
Battery
2 hours general use, 2.5 hours video watching
Up to 2.5 hours of general use; 3 hours video watching
Connectivity
Wi-Fi 7 (802.11a/b/g/n/ac/ax/be); Bluetooth 5.4
Wi‑Fi 6 (802.11ax); Bluetooth 5.3
IPD
54–70mm
51–75 mm
Weight
545g with forehead cushion (not including light shield)
Battery weighs 302g
750–800 grams, including cushion, light seal, and dual knit band
Battery weighs 353g
Samsung sells Galaxy XR in one 256GB storage configuration with 16GB of RAM. Apple offers more storage options, with the headset starting at 256GB and going up to 1TB.
When equipping the Galaxy XR with cameras and sensors, it looks like Samsung took a few cues from Apple Vision Pro. Both headsets feature two passthrough cameras, six world-facing cameras, and four internal eye-tracking sensors. Each one also offers a depth sensor, four inertial measurement units, and a flicker sensor. Apple set the baseline, and Samsung matched it.
The Samsung Galaxy XR headset, carrying case, and controllers on four pedestals above a white, lit surface.
However, Apple still goes a step beyond with a LiDAR scanner and TrueDepth camera. Each headset comes with two open-air speakers for audio playback.
Samsung is the winner in connectivity, supporting Wi-Fi 7 and Bluetooth 5.4 on the Galaxy XR. Apple Vision Pro still only supports Wi-Fi 6 and Bluetooth 5.3. Considering so much on Vision Pro is done wirelessly, it's shocking that the headset still supports such an outdated standard.
Samsung Galaxy XR vs. Apple Vision Pro: Apps and software
A photo of a Samsung engineer playing Walkabout Mini Golf while wearing the Galaxy XR headset and using a Galaxy XR controller in her right hand, a screen showing the game behind her.
Samsung's Galaxy XR is the first headset to run Android XR, while Apple's Vision Pro runs visionOS 26. Both operating systems aim to leverage the Google and Apple app ecosystems, respectively, to deliver the best experience. Ideally, the Google Play Store and App Store support allows XR headset users to access their favorite apps without developers needing to build for these specific platforms.
In practice, that doesn't work great on Vision Pro. Developers can choose to opt out of the platform, and some big names already have. When an app isn't optimized for Vision Pro, it effectively runs in a virtual iPad-sized window.
There are some things about visionOS that just make sense, like navigation, spatial photos and videos, and widgets that you can place on your real-life walls. However, apps and content explicitly built for Vision Pro feel lacking over a year after its release.
A clip of a video from Apple about spatial input design
(Image credit: Apple)
Android XR feels like a winner in app and content support, but it's too early to know for sure. It leverages the Google Play Store ecosystem similarly to Vision Pro, and adds 30 games built specifically for the headset. It can be used with apps like Virtual Desktop for productivity and PC VR applications.
If you're still craving more, the Samsung Galaxy XR's onboard USB-C port can take in display data from basically any source, turning the headset into a virtual monitor.
Samsung Galaxy XR vs. Apple Vision Pro: Which should you buy?
A photo of the author wearing the Samsung Galaxy XR headset, holding up one hand in a pinch gesture.
Of the two headsets, Samsung's Galaxy XR will provide a better experience today than Apple Vision Pro. It's also a better value, costing about half the price of Vision Pro while delivering similar hardware. When you consider all the perks you get if you buy Galaxy XR before 2026 — a year of Google AI Pro, YouTube Premium, NBA League Pass, and more — the headset becomes a pretty solid deal.
There are a few aspects of Vision Pro that exceed Galaxy XR's capability. Notably, the headset is powered by the Apple M5 chip, which can run laps around the Snapdragon processor in Galaxy XR. That enables real-world perks, like 120Hz refresh rates. However, it feels like the visionOS app ecosystem isn't ready to utilize the Vision Pro's hardware advantages.
For now, the Samsung Galaxy XR is the extended-reality headset to buy if you want next-generation hardware and a great app ecosystem. It's still a tough sell, much like Vision Pro, because of its price. There are cheaper options available now, such as the Meta Quest 3 or Quest 3S, and the price of premium headsets will surely come down over time.
Brady Snyder
Contributor
Brady is a former contributor for Android Central, who wrote for the site from 2023 to 2026. With a focus on news, phones, and audio, he spent years reporting and commenting on all things related to consumer technology.
Brady reviewed Apple, Google, Samsung, and Motorola phones for Android Central, and attended industry-wide events like IFA and MWC on behalf of the publication. He holds a bachelor's degree in journalism from St. John's University.
His work has been published in XDA, Android Police, Android Authority, MakeUseOf, and SoundGuys, among other sites. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
