Honor Magic 8 Pro vs. Magic 8 Lite: It's an easy choice
Honor Magic 8 Pro vs. Magic 8 Lite: Design
(Image credit: Nick Sutrich / Android Central)
Honor isn't making many alterations when it comes to the design of its latest phones. Both devices have roughly similar dimensions, but the Magic 8 Pro is heavier because of the aluminum mid-frame, giving it better rigidity. The Magic 8 Lite is made out of plastic, and while there are no issues with build quality, it doesn't quite have the same feel.
Thankfully, both devices get IP68 and IP69K dust and water resistance, so they should hold up just as well at the pool or in the shower. The Magic 8 Pro has a massive camera island, and it looks like a natural evolution of what we saw on the Magic 7 Pro last year. The Magic 8 Lite has a cleaner design, and if anything, I like the way it looks a little better.
Honor went with a plastic rear on both devices, with the Magic 8 Pro using a fiber-reinforced material that gives it a better in-hand feel. Outside of that, there isn't much to differentiate the devices at least when it comes to the design.
Honor Magic 8 Pro vs. Magic 8 Lite: Hardware
This is where you'll see a real difference between the two phones. With the Magic 8 Pro, Honor went with the latest Qualcomm silicon, putting the device on par with the iQOO 15 and the upcoming Galaxy S26. But the Magic 8 Lite gets the 4nm Snapdragon 6 Gen 4, and although it is decent enough, it doesn't have anywhere close to the kind of power as the Magic 8 Pro.
Another limitation is the memory; the Magic 8 Pro gets the standard 12GB memory, but the Magic 8 Lite only gets 8GB, and Honor really should have included 12GB on both models. You don't get UFS 4.1 storage on the Magic 8 Lite either, and it misses out on Wi-Fi 7, Bluetooth 6.0, and USB-C Gen 3.2. Basically, Honor made several changes to the Magic 8 Lite, and the result is a device that doesn't measure up to other phones in this category, much less the Magic 8 Pro.
The upside is that the Magic 8 Lite dominates when it comes to the battery; thanks to a massive 7,500mAh battery, the phone manages to last two days between charges. The Magic 8 Pro is pretty decent in this area as well, but the global model doesn't quite measure up to its Lite sibling.
Honor Magic 8 Pro vs. Magic 8 Lite: Cameras
The Magic 8 Pro has a trio of great cameras, and you get a similar level of versatility as the best Android phones. The main 50MP camera shoots outstanding photos in all situations, and the 200MP tele lens is great in its own right. It's not quite as good as the Vivo X300 Pro or the Find X9 Pro, but it is better than what Honor managed last year.
The Magic 8 Lite, on the other hand, gets a main 108MP module and a paltry 5MP wide-angle lens, and as you can imagine, the secondary lens is average at best. You don't get a dedicated telephoto, and that's annoying to say the least.
Honor Magic 8 Pro vs. Magic 8 Lite: Software
Normally, I'd say that the software is the same on these devices, but that isn't the case. The Magic 8 Pro comes with Android 16 out of the box, but the Magic 8 Lite is still on Android 15, and that's infuriating. What's even more egregious is that the Magic 8 Lite won't get as many software updates; with six guaranteed updates, the phone will get two fewer Android platform updates as the Magic 8 Pro.
Other than the update situation, the software is roughly similar on either device. Honor is badly in need of a visual overhaul, and while the brand insists that its software is built in-house, there are too many Huawei-esque influences still around. With other brands rolling out new interfaces and modernizing their software, the Magic 8 Pro and 8 Lite look a little outdated.
Honor Magic 8 Pro vs. Magic 8 Lite: Which should you buy?
Of the two, the Magic 8 Pro is clearly the better device, but that's obvious. The device doesn't really have any limitations, and it holds its own against the likes of the Galaxy S25 Ultra and the Pixel 10 Pro.
The Magic 8 Lite also has a lot going for it, and that's particularly the case when it comes to battery life and ingress protection. If that's what you need, then yes, the Magic 8 Lite is a good choice. But the phone isn't quite as good when it comes to the cameras, or even the hardware, with Honor shortchanging buyers on small things like the Bluetooth modem. I also don't like that the phone is running Android 15 instead of the latest Android 16.
If you need the best that Honor has to offer, the Magic 8 Pro is the phone you should buy. If you need a mid-ranger with the best value, I'd suggest taking a look at the Pixel 9a or the Xiaomi 15T.
Harish Jonnalagadda
Senior Editor - Mobile
