Batteries for your Motorola Droid
Standard Droid batteries
The stock battery for the Motorola Droid is a great purchase for those who need to replace their original battery, or would just like an extra one to carry with them while on the go. Having a replacement with you while on the road could be the difference between making that important call or missing it.
Seidio 2600mAh Extended Life Battery
Extended batteries for the Motorola Droid take your battery life to the next level. While adding some bulk to the device, the life of the battery is nearly doubled with this battery, which is very important for many. If you can work with the size, this is definitely a worthy investment for those who are on the go, and can't risk a dead Droid.
