I use my phone for everything so I made the choice early on to spring for the extended battery. The additional hours it’s given me are well worth the few ounces it adds to my Incredible. Unfortunately, this limits what cases I can use.
I’m not much of a case guy. I don’t want a plastic cover to show off my favorite team, and I don’t have some overwhelming desire to have a blue, white, or green phone. I use a case because I want to protect the device. The problem is that once you move out of the fitted case market, the cases become “one-size-fits-all” monstrosities that claim to fit everything from the Samsung Juke to the Galaxy Tab.
The Smartphone Experts Top Case for the Droid Incredible (among other phones) is a welcome change from that norm. Instead of trying to make a single case for everything, they focused on a specific form factor (in this case, 3.7inch screens) and gave it just enough give to accommodate the extra battery without adding a ton of unnecessary bulk. The case is available in two additional colors (red or tan) but I settled on the standard black since I planned on clipping it to my belt.
The case is made out of high quality leather that’s soft to the touch. With an extended battery, the fit is a little snug, but after a few days the sides loosen up enough so that you can easily pull your phone out when needed without becoming so loose that you’re phone will fall out of it whenever the top isn’t secured. The top flap is secured by using magnets, which give the front a smooth appearance.
The back clip is made out of metal, and whatever they used is strong enough to resist warping or bending. This also means that it’s magnetic, allowing you to secure the top flap to it if you prefer to have the top of the case open for easy access. When I wore the case, I never fell off my belt, and the clip is positioned in such a way so that the case sits low and won’t bite into your side if you sit down while wearing it.
If you’re looking for a new case for your Incredible, the Top Case is an excellent choice. The build quality is top notch, and the leather gives it a professional look. For those of you with the HTC extended battery, it gives a near perfect fit without becoming so large that someone might mistake it for a man-purse. The Smartphone Experts Top Case for HTC Droid Incredible is on sale right now for just $24.95, so be sure to check it out. More pictures after the break.
- Filed under:
- Tags:
615(forum posts)
