Trident Cyclops Case for the Samsung Galaxy S5
One of the toughest Galaxy S5 cases you'll find anywhere
If you're in the market for a rugged, takes anything you throw at it kind of case for the Samsung Galaxy S5 then look no further. The Trident Cyclops is for you. This thing is insanely tough, durable and great value for money to boot.
The Cyclops is actually a two-piece case. The main shell is made of a hardened polycarbonate and is super sturdy all the way round the sides and back. There's very little flex in it at all and you've got flaps covering the headphone jack and charging port and replacements for the power and volume buttons. But that's only half of it.
The phone is held in place by a second piece which not only acts as a second layer to the sides of the case but also as a pretty substantial screen protector for the phone. Once the phone is inside the Cyclops there's very little that can get at it. Including you.
That's probably the biggest drawback to the Cyclops. Once you've got the phone in there getting it out is probably tougher than it ought to be. That's in part due to just how tough this thing is. The combination of almost no flex in the sides of the outer shell with lugs on the inner shell that hook in and keep the phone in tight means that you really do have to fight it out of there.
And that's about all there is to it. It's certainly not the slimmest nor the most glamorous case you'll ever see, but it's ridiculously tough. If that's what you need, definitely give it a look.
Check out some of the most popular Samsung Galaxy S5 accessories at
