The SanDisk Ultra 32GB microSD card and adapter 2-pack is down to just $6.99 at Woot for Amazon Prime members. It's listed at $11.99, but logging in with your Amazon account automatically saves you a further $5 at checkout. While this particular card is no longer available at Amazon, one similar SanDisk Ultra 32GB card would cost you $8 alone. By using your Prime account, you'll also be granted free shipping.
Store more
These are a great addition to your phone, tablet, action cam, and so much more. At just $7 for a total of 64GB of space, you can easily afford a pair — so don't miss out!
$6.99 $16.00 $9 off
You can use these microSD cards to add storage space to your phone, tablet, Nintendo Switch, dash cam, home security system, and more. The included SD adapter means it will work great with an even broader array of devices too. Each has speeds up to 80 MB/s and Class 10 for full HD video recording and playback. The cards are also resistant to shock, extreme temperatures, water, and X-rays.
While we have seen nice deals on the larger capacities recently, there are plenty of devices such as Yi action cameras that max out in the size they support. It's also a great way to save money when buying an affordable tablet like Amazon's base-spec Fire 7. It only has 16GB internally, but you can add much more with this card for less than the cost to upgrade to the 32GB model.
We may earn a commission for purchases using our links. Learn more.
