The Magic 8 Pro Air proves that Apple and Samsung got their thin phones wrong
The Honor Magic 8 Pro Air proves that thin phones can be true flagships
Holding the Honor Magic 8 Pro Air
(Image credit: © © Nirave Gondhia)
Android Central Verdict
This is the best thin phone ever made, and it's not even close. If the iPhone Air and Galaxy S25 Edge battery and camera compromises stopped you from buying it, this is the thin phone you've been waiting for... if you're able to.
Reasons to buy
    Outstanding battery life
    Superfast charging
    Vibrant display
    Solid performance from the chipset
    Excellent camera performance
    IP69 protection against high pressure jets
Reasons to avoid
    Under-display fingerprint sensor is slightly too low
    Only available in China
After 18 years of reviewing technology, it’s quite rare that smartphones can truly surprise or excite me, but last year marked a big moment. I love small phones and thin phones, which bucks the trend of bigger devices, and the iPhone Air and Galaxy S25 Edge both left me enamored when they were announced.
Yet neither became my main phone for one key reason: compromises. Both phones feature considerable compromises compared to their non-thin counterparts, especially as the latter become increasingly thinner with each generation.
The reason seemed simple: a thin body would naturally lead to several compromises in performance, battery life, charging, and camera performance. At least it seemed to be until a couple of weeks ago when I started using a new thin phone that proved that Samsung and Apple got it wrong.
Meet the best thin phone ever made: the Honor Magic 8 Pro Air. It’s so good, it’s my favorite phone to use right now.
Thickness of the Honor Magic 8 Pro Air in orange
(Image credit: Nirave Gondhia)
The Honor Magic 8 Pro Air is slightly thicker than the Galaxy S25 Edge and the iPhone Air, but this is a worthwhile trade-off. The Magic 8 Pro Air measures 6.1mm thin, compared to 5.6mm for the iPhone Air and 5.8mm for the Galaxy S25 Edge, but while it's 0.6mm thicker, you’ll be grateful for it.
Swipe to scroll horizontally
Honor Magic 8 Pro Air Specs
Specs
Build
150.5 x 71.9 x 6.1 mm
155 grams
Glass front + aluminum frame
Display
6.31-inch LTPO OLED
1216 x 2640 pixels
4320Hz PWM, 120Hz refresh rate
Dolby Vision, HDR
1800 nits HBM/6,000 nits peak brightness
Chipset
MediaTek Dimensity 9500 SoC
Memory/Storage
12GB RAM/256GB
12GB RAM/512GB
16GB RAM/512GB
16GB RAM/1TB
Main Camera
50MP, f/1.6, 23mm, 1.2µm, multi-directional PDAF, OIS
Ultrawide Camera
50MP, f/2.2, 16mm, 112° field-of-view
Telephoto Camera
64MP periscope telephoto, f/2.6, 74mm, 3.2x optical zoom, OIS
Selfie Camera
50MP, f/2.1, 21mm
Battery
5,500 mAh Silicon Carbon
Charging
80W wired charging
55W wireless charging
Connectivity
Wi-Fi 7, Bluetooth 6.0, NFC, GPS, USB-C 2.0 OTG
Nano-SIM + eSIM
Colors
Black, White, Purple, Orange
Price
Â¥4,999 (~$717)
The reason? Much better cameras, a much larger battery, and considerably faster charging. The result is the only thin phone that feels like it doesn’t really compromise the flagship phone experience, especially compared to the competition.
It’s also worth noting that Honor managed to do all of this in a body that’s smaller than the competition as well, which makes the Magic 8 Pro Air even more enjoyable to use.
USB-C port on the Honor Magic 8 Pro Air in orange in the hand
The Magic 8 Pro Air features a vibrant 6.31-inch display, complete with Dolby Vision and 6,000 nits peak brightness, and it resonates with me because I love small phones; this is much more comfortable to use in one hand than the 6.5-inch display on the iPhone Air (which is near perfectly sized) and the 6.7-inch display in the Galaxy S25 Edge, which I find a little too large.
If Honor had picked a larger display, it might not have been as enjoyable for me, but there’s a strong chance they could have made it thinner as well. Regardless, this is among the best-designed phones I’ve used in years, and as we’ll see, it finally addresses the key compromises of other thin phones. It also comes in four colors — Black, White, Purple, and Orange — and yes, I’m using the now-very-familiar Orange variant that looks just as stylish as my iPhone 17 Pro.
The Honor Magic 8 Pro Air in orange in the hand
Battery and charging are key areas in which the Magic 8 Pro Air excels compared to the competition, and simultaneously solves the biggest issue with other thin phones.
The iPhone Air features a 3,149 mAh battery, with Apple also making a separate iPhone Air MagSafe battery pack that close to doubles the capacity. At around 7mm thick, this more than doubles the iPhone Air's overall thickness to ~13mm when used together. Meanwhile, the Galaxy S25 Edge features a larger 3,900 mAh battery with no official Qi2 battery pack.
Battery menu on the Honor Magic 8 Pro Air in orange in the hand
In comparison, the Magic 8 Pro Air excels considerably, featuring a 5,500 mAh battery with support for 80W wired charging and 50W wireless charging. For context, this is larger than the battery in the iPhone 17 Pro Max, the new Galaxy S26 Ultra, or even folding phones like the Galaxy Z Fold 7. It takes around 50 minutes to charge the Magic 8 Pro Air to full, which is also faster than both the iPhone Air and the Galaxy S25 Edge.
I was shocked by the battery size, and then even more shocked when it delivered the exact all-day battery life I’ve been waiting for from a thin phone. Over the past few weeks, the battery life has averaged around 5-6 hours of screen time per day, which is more than enough, but I’ve also had it go over seven hours when used mostly on Wi-Fi. This is incredible, and simply put, the Magic 8 Pro Air is the first thin phone to offer true flagship battery life.
Camera on the Honor Magic 8 Pro Air in orange in the hand
The camera is another area in which the Magic 8 Pro Air excels. The iPhone Air features a single 48MP camera, while the Galaxy S25 Edge features a 200MP main camera and a 12MP ultrawide camera. Yet both lack the full range of camera features you’d find in either company’s flagship phones, which is another reason some customers may have opted against the thin variants.
The Honor Magic 8 Pro Air doesn’t have such compromises.
The Magic 8 Pro Air shows that thin phones can have great cameras, thanks to a 50MP main camera with f/1.6 aperture, a 50MP ultrawide camera, and a 64MP periscope telephoto camera with 3.2x optical zoom.
This is virtually identical to the camera system found in the new Honor Magic V6 folding phone, but the Magic 8 Pro Air also has a much better 50MP selfie camera.
I’ve been waiting for a thin phone that actually delivers in the camera department, and this is the first phone not to disappoint: the Honor Magic 8 Pro Air is the first thin phone to actually deliver a flagship camera experience, and it’s absolutely wonderful to use in real-world usage.
Thin phones often struggle with cooling under heavy performance, but the MediaTek Dimensity 9500 processor inside the Magic 8 Pro Air stays noticeably cooler than any other thin phone, even when using on-device AI features.
Similarly, Honor’s software is well-optimized for both the form factor and the lack of thermal window, and the phone has yet to struggle, crash, or lag in any way. Yes, it runs a Chinese ROM, so you can’t set a different default launcher, but aside from that small point, Honor’s Magic UI is fantastic and intuitive to use.
Selfie camera on the Honor Magic 8 Pro Air in orange in the hand
There’s also full support for Google Apps, support for eSIMs — which is extremely rare on Chinese phones — and even a SIM tray, which is missing from the iPhone Air. This could easily launch globally with very few tweaks to the UX.
The under-display fingerprint sensor works well, but I do wish Honor had adopted a fingerprint sensor on the power button instead. And just to prove it’s truly a flagship, there’s also IP68 and IP69 dust and water resistance, with the latter proving to be a key differentiator that many non-thin phones don’t even offer.
Back and camera on the Honor Magic 8 Pro Air in orange in the hand
The Magic 8 Pro Air is the best thin phone ever made.
This is a big statement, and the caveat is that there aren’t that many. Having tried every thin phone — including the Tecno, Huawei, and Motorola versions that are limited to China or elsewhere — one thing is clear: the Magic 8 Pro Air is the best thin phone ever made.
I’ll take it a step further: it’s one of the best phones ever made, thin or otherwise. Honor has proven that thin phones can be made without many compromises, and in doing so, it’s set a benchmark for other companies to follow. If a thin phone can be this good, what does it mean for non-thin phones going forward? Regardless, it's already one of my favorite Android phones, and aside from the best folding phones, it's setting a benchmark that I'm not sure the competition will beat.
The only downside to the Magic 8 Pro Air? It’s exclusive to China only, at least right now. It starts at ¥4,999 (~$717) for the 12/256GB version in China, with the top variant costing ¥5,999 for 16GB of RAM and 1TB of storage. It would be more expensive in global markets, but there’s no doubt in my mind that Honor needs to bring this to global markets. It’s that good that every country deserves to be able to buy this.
Nirave Gondhia
Veteran Tech Journalist
Nirave is a veteran tech journalist and creator at House of Tech. He's reviewed over 1,000 phones and other consumer gadgets over the past 20 years. A heart attack at 33 inspired him to consider the Impact of Technology on our physical, mental, and emotional health. Say hi to him on Twitter or Threads
