4 things to pay attention to when trying to pick the right phone charger for your Android phone
Various USB-C chargers from Anker, UGREEN, and Baseus.
(Image credit: Namerah Saud Fatmi / Android Central)
Gadget Weekly
Inspector Lloyd
Join Namerah Saud Fatmi as she explores the cool, quirky, and sometimes downright odd world of smartphone accessories, gadgets, and other nerdy toys every week.
How do you know which charger is right for your Android phone? This is a question I get asked all the time, and one that I never tire of answering. That's because helping others find the perfect accessory for their needs is incredibly satisfying.
As with any decision in life, tech-related or otherwise, there's no one-size-fits-all solution. Instead, you need to identify the right specs your phone needs, take your budget and other important factors like habits into account, and then find a charger that fits the bill.
I have developed a bulletproof strategy of finding the right charger that I like to call the "four Ps method". The four Ps in question are ports, power, profile, and price. Once you know the right Ps, you can find the exact charger that suits your needs. Here's how you can pick the best phone charger for your Android phone using my fail-safe formula.
Ports are the first thing to consider
Satechi 200W 6-port USB-C GaN charger
Let's start with the number of ports you need on a charger. Buying a brick with a single USB port is inefficient and highly inflexible. You would only be able to charge your Android phone at a time, nothing else.
A single-port charger will also force you to choose between USB-C and USB-A. In this day and age, a dual-ported charger is the bare minimum for everyone. At the very least, get a dual-port adapter with one USB-C and one USB-A port, so you can use any cable and charge at least one other device simultaneously.
If you want a blanket recommendation, I'd say choose a three-ported charger with two USB-C and one USB-A port. That's the right mix, ideally, as most devices charge via USB-C to USB-C cables, and you will still have a good old USB-A port just in case.
Power rating matters a lot on chargers
UGREEN Nexode 100W
(Image credit: Harish Jonnalagadda / Android Central)
The power rating of a charger is a crucial factor. You need to know the power output and match it to your Android phone's supported charging speed. All flagship phones from Samsung and Google support 25W or higher, up to 45W or 60W. Motorola phones go up to 68W and higher, while Chinese Android phones are even more cutting-edge, with brands like OnePlus, Xiaomi, Vivo, RedMagic, and OPPO offering 80W, 100W, and even higher charging speeds.
Even if your phone can only take 25W, keep in mind that a dual-port 25W charger will split that power between the two ports when both are in use. Since I recommend three-ported bricks for most people, I say invest in a 60W USB-C charger to hedge your bets. Even with all the ports in use, your Android phone will still get fast charging speeds. If you are planning to use your charger with a laptop or Chromebook, or if your phone charges at 80W or higher, try to go for a 100W option at the very least.
Pro tip: If you get a 60W or above charger, make sure the USB cable also supports that power rating.
Know your charging profiles as they vary across brands
Charging a OnePlus 15 with the included Super VOOC ultrafast charger
Without getting too technical, a charging profile manages voltage, current, and other important things. You might have heard words like PPS (Programmable Power Delivery), PD (Power Delivery), QC (Quick Charge), SuperVOOC, Samsung Fast Charging, and more.
These charging protocols matter because even if your Android phone supports 60W and your charger supports 60W, you might not actually get that charging speed if the charger's charging profile doesn't match your phone. For example, a basic 45W charger might not work at the maximum possible speeds with a Samsung Galaxy S26 Plus or the Google Pixel 10 Pro. You will need to ensure the charger supports Samsung's or Google's fast-charging profiles, which generally use PD and PPS for faster speeds.
Price is unquestionably important to find a budget-friendly pick
Baseus PowerCombo GaN3 Pro charging station
(Image credit: Jay Bonggolto / Android Central)
Once you've sorted out the number of ports you require, how much power your Android phone needs, and which charging profiles to watch out for, the price comes into play.
Chargers don't cost much these days thanks to the competitive market. You can find all kinds of USB-C chargers with unique features and functions. However, the best in class come at a price.
Narrow down all the chargers that fit the specs I have helped you identify so far, then find something within your budget. If you find that the charger you want exceeds your budget, perhaps reduce the number of ports and opt for a dual-port pick instead of a tri-port one.
Mercifully, trusted brands like UGREEN, Baseus, and Anker make some of the best chargers in the world and cater to all price segments. Even if you're limiting yourself to $30, you will be very pleased with what these brands have to deliver.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
