I put a magnetic ring on my non-wireless charging phone — here's why you should too
Honor Play 10 with a clear case, a magnetic ring sticker, and MagSafe accessories.
(Image credit: Namerah Saud Fatmi / Android Central)
Magnetic accessories are designed for MagSafe, Qi2, and Pixelsnap ecosystems. All phones that support these features also support wireless charging, and there is a general understanding that magnetism benefits those who want magnetic wireless charging accessories the most.
As useful as a magnetic wireless charger is, it is not the only reason to want native magnetic support on a smartphone. I frequently add magnetic ring adapters to devices that don't support wireless charging at all, and it has been a game-changer.
What can I say, I'm attracted to magnets
I recently installed a magnetic ring sticker on a clear Honor Play 10 case to use the Play 10 with the ESR Qi2 wireless car charger in my ride. It doesn't make sense to swap out the wireless car charger for the sake of one phone.
While it doesn't charge my phone, I can now mount my non-Qi2 device on the magnetic car charger to use it as a holder. And when I'm using Qi2 devices like my Pixel 10, I get the wireless charging privileges. No harm, no foul.
There are plenty of MagSafe accessories for Android, as well as Qi2 or Pixelsnap accessories that aren't charging-based. In fact, you can even use some charging accessories, so long as they have wired charging as well.
If you have a magnetic power bank that supports wireless charging, it definitely has at least one USB-C input/output port. Although you can't wirelessly charge a device that doesn't have the ability, you can definitely mount the power bank on the back of said phone and plug the cable in to top up the battery.
Planting a magnetic power bank on the back of a phone that cannot charge wirelessly has its advantages. You won't forget your phone is charging and drop the power bank on the floor. And if your power bank has a stand, you can prop up your device.
It's also much easier to operate a phone while it's hooked to a power bank if the power bank is securely attached to the back.
Every other fun magnetic accessory can easily be used with a non-wireless charging phone once you add a magnetic ring. Anything from magnetic wallets and kickstands to phone mounts and suction cup grips becomes available to use.
If you have a wireless charging stand, unplug it and use it as a phone-holding stand. In a household, it is highly likely that some residents have a MagSafe iPhone, some use Qi2 Android phones like the Pixel 10, and some sport devices that don't have any magnetic support.
The trick is to buy the right magnetic accessories
Having a mixed variety of devices at home does not require you to purchase different accessories for different devices. If anything, you should strive to buy something that works for everyone. For instance, my partner has two phones, neither of which has native magnetic support or wireless charging compatibility. Meanwhile, I have a mix of several devices that can do either one or both of these things.
I have stuck magnetic rings on every single phone at home. Thus, we can freely use each other's magnetic accessories. The convenience is freeing. Either of us can use the magnetic car charger as a mount when driving. If I'm carrying a Qi2 power bank, I make sure I take one with a USB-C cable so both of us can use it.
When I'm bored with my phone grip, we swap for a while. And when either one of us needs to use a stand or a phone holder, we don't have to worry about anything. All of the ones we have at home are magnetic, so both of us can use them. When we're going on holiday, we take only one MagSafe phone stand to watch movies or YouTube.
So, it doesn't matter whether your phone can charge wirelessly or not. Just add a magnetic ring to it and invest in the right kind of accessories to enjoy the same level of convenience as I do!
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
