Don’t buy a power bank until you see my 4 favorite picks for 20,000mAh and above
High capacity power banks 20,000mAh
(Image credit: Namerah Saud Fatmi / Android Central)
If you're reading this, you're likely in need of a 20,000mAh power bank. Before you do a quick search on Amazon or Best Buy, you need to know these four excellent high-capacity power banks within that range so you get the most value for your money.
A lot of people find it perfectly acceptable to buy any power bank, so long as it comes from a reputable name brand. Meanwhile, some people really only care about the price. But you can't go off these factors alone in your hunt for the right 20,000mAh power bank.
Price and trustworthiness of the manufacturer aside, International Air Transport Association (IATA) approval, size, weight, ports, charging speed, and inclusion of a good USB cable are all important factors to consider. My top four picks take all of these aspects into consideration, and all of them have a display. Let's start with the one that I prefer the most from INIU.
The most compact option: INIU Cougar P63-E1 100W 25,000mAh Power Bank
The INIU Cougar P63-E1 100W power bank is the most compact portable battery you will find that has a 25,000mAh capacity. It is the best power bank in the 20,000mAh range for multiple reasons. Small enough to fit in your pants pocket, the INIU Cougar P63-E1 is also impossibly lightweight at just 392.3 grams. For reference, the Samsung Galaxy S26 Ultra weighs 214 grams. This is easily the lightest 20,000mAh+ power bank you will find.
In addition to its compact, pocketable nature, INIU assures compliance with most airline regulations around the world. Since it supports 100W output and 65W input charging speeds, you can charge phones and laptops on the go at full power and recharge the power bank itself at lightning-fast speeds. You get two USB-C and one USB-A ports, and as an added bonus, INIU includes a 100W cable that doubles as a lanyard.
Priced at about $67 to $70, depending on ongoing promotions or discounts, it doesn't cost too much either. A 100W cable for free is a neat deal.
The cheapest option: Baseus EnerCore CR11 Power Bank 20,000mAh 67W
The Baseus EnerCore CR11 Power Bank is a sleek 20,000mAh battery pack with 67W fast charging output. This option is almost as light as the one from INIU, but it only has two USB-C ports. Baseus added a tangle-free retractable USB-C cable to the EnerCore CR11, which means you don't have to worry about carrying a separate cable. This blocks the second port, though, and you can only recharge it with a power bank at 45W.
At just 394g, the flight-approved Baseus EnerCore CR11 is almost as light as the one from INIU, but not as small. It is, however, the slimmest of the lot. If you can find it in stock, this is also the cheapest option, priced at just $50.
The best for airplanes: UGREEN Nexode Power Bank 20,000mAh 165W with Retractable USB-C Cable
I'm not alone in my love for the UGREEN Nexode 20,000mAh 165W power bank that comes with a 100W retractable USB-C cable. My colleague Harish Jonnalagadda had an equally satisfying experience with this relatively compact 165W power bank.
Although this 550-gram unit is moderately heavy, it has official IATA approval. There's an additional USB-C port without the retractable cable, as well as a USB-A port. You can recharge it in just 1.9 hours thanks to its incredible 100W input charging speed.
Usually priced at $100, it goes on sale pretty frequently. You can get it right now for $80 or wait for an amazing deal during Amazon Prime Day or Black Friday to get it for even cheaper. All in all, a combination of fast charging and recharging, the right ports and cable, as well as the juicy price, makes this the ideal flight partner.
The wireless charging option: Anker Prime 27,650mAh Power Bank (250W)
Coming in at a hefty 665 grams, the Anker Prime 27,650mAh Power Bank (250W) is the heavyweight champion of 20,000mAh power banks. This isn't a luxury everyone can afford as it retails for a whopping $180. However, it has one unique feature that stands out from the other picks: wireless charging support.
The Anker Prime 27,650mAh Power Bank supports a total 250W output and 100W input. If you buy the 100W magnetic wireless charging base, you can wirelessly recharge it in just 10 to 15 minutes, but it costs another $100.
It is TSA approved, has one USB-A and two USB-C ports, and comes with a 140W Type-C cable in the box. You can connect to the Anker Prime 27,650mAh Power Bank via Bluetooth and monitor it on the Anker smartphone app.
When neither money nor bulk matters, this is the best possible 20,000mAh power bank to purchase.
The bottom line
Between these four 20,000mAh power banks, there's nothing amiss. Each one has a display that showcases the power bank's status, charging speed, input/output, and various other useful information.
Based on your most prioritized feature, you can pick any one of these excellent options worry-free. INIU, Baseus, UGREEN, and Anker are masterful accessory makers. There's no going wrong with any one option. Just make sure you pick something that matches your needs.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
