Act now — my go-to Qi 2 travel power bank is finally under $30
Baseus PicoGo AM31 5000mAh Power Bank testing on Android Central
(Image credit: Apoorva Bhardwaj / Android Central)
A lot of the recent innovations in power banks have been around Qi 2 charging tech. There's a decent amount of choice if you need a good power bank, and I use the Baseus Picogo, which just got a discount and is down to $28 right now.
The Picogo is a 10,000mAh power bank, and it has a sleek design with powerful magnets that let you attach it to your iPhone and Pixel without any issues. I used this model with my Pixel 10 Pro XL and iPhone 17 Pro, and after a year of use, I didn't see any issues whatsoever.
Baseus Picogo Qi 2 10,000mAh Power Bank
Save 29%
Baseus Picogo Qi 2 10,000mAh Power Bank: was $39.99 now $28.47 at Amazon
I used this power bank for a year now, and it has been reliable. MagSafe connection is solid, the 10,000mAh battery is enough to charge your phone fully, and it is lightweight.
✅Recommended if: You want a Qi 2 MagSafe power bank that's lightweight and reliable in daily use. The Picogo power bank has a 10,000mAh battery, Qi 2 with 15W charging, and a USB-C port that hits 22.5W when you need to plug in.
❌Skip this deal if: You need Qi 2.2 with 25W charging. In that case, get the Baseus Picogo AM52, which is now $52.
There's a lot to like with the Picogo power bank. The 10,000mAh battery is enough to charge a phone fully, and I really like the design; the metal chassis makes it durable, and the Qi 2 magnets are strong — they attached to my iPhone and Pixel without any problems.
With Qi 2 connectivity, you get 15W charging, and while it's on the slower side, it is adequate while traveling as the power bank stays connected to the phone. This is a big advantage over regular power banks, and the size and weight of the Picogo gives it an edge over its rivals.
There's a dedicated USB-C port that goes up to 22.5W, and this is useful if you need to plug in a secondary device to the power bank. Note that while the power bank has a 10,000mAh battery, it doesn't mean you'll be able to charge your phone twice over. Because of charging efficiency and the inherent energy that's lost while charging your phone, you'll get close to 5,500mAh of actual usage power out of the Picogo, and that is in line with other power banks in the industry.
If you need Qi 2.2 with the full 25W charging, you'll want to get the Picogo AM52. It has the same design and the same 10,000mAh battery, and the magnets are the same as well. The biggest difference is that it's able to deliver a 25W charge consistently, and I found that to be a decent enough differentiator when I need to charge my phone. But because of the newer standard, the AM52 costs a lot more — you'll be shelling out $52 to get your hands on the power bank.
Honestly, the regular Picogo should be more than adequate for most, and the best part is that it is now available for under $30, making it a good overall option.
Harish Jonnalagadda
Senior Editor - Mobile
