Don't need a 300W charging station? These 4 features will change your mind
Cuktech 30 Ultra charging station review on Android Central
(Image credit: Apoorva Bhardwaj / Android Central)
Charging devices can get out of hand, particularly if you have a few phones, notebooks, tablets, and accessories. You can just use the charger that comes in the box with the phone (which in itself is vanishingly rare these days), but a much better choice is to get a dedicated charging station. Going this route will allow you to charge all of your devices at once, and you get much more power than with a single charger — I use UGREEN's Nexode 500W charging station, and its six ports allow me to charge all of my tech with ease.
Cuktech is a Chinese charging brand that's slowly gaining momentum; I use its 15 Ultra power bank and 140W charger daily, and its products are just as reliable as UGREEN and Anker. The brand is now making charging stations, and I've been testing the 300W 30 Ultra for the better part of a month now. The 30 Ultra retails for $159 on Amazon, and while that is costly, you are getting a charger that can easily charge up to five devices at once. To put this into context, the Nexode 500W that I use in my office costs $199.
If you're not quite sure about what you get with a charging station, these are four things I liked the most about the Cuktech 30 Ultra after a month of testing.
The Cuktech 30 Ultra has all the ports you need
Obviously, the biggest reason for buying a GaN charging station is to be able to charge several devices at once. The 30 Ultra has three USB-C ports, one USB-A port, and a DC connector on the side that lets you connect to notebooks.
The charger also gets a wedge-style stand that angles it on a desk, and this makes the accessing the ports a little better.
When it comes to USB-C, you get 140W over the USB PD 3.1 protocol with the USB-C1 and C2 ports, and the best part is that both ports can deliver 140W at once. This means you can effortlessly charge two MacBooks simultaneously with the 30 Ultra, and that's a big advantage.
The USB-C3 port goes up to 33W, and the USB-A port hits 18W. Cuktech bundles a 240W USB-C to USB-C cable in the box, and you can use it to charge just about any gadget.
It has (almost) all mainstream charging protocols
Most charging stations just get USB PD and leave it at that, so it's great to see Cuktech add a lot of additional charging protocols. That includes Xiaomi's 120W charging standard, and I tested it with the Xiaomi 17 Ultra and Xiaomi 17T Pro to confirm. You also get 100W USB PD with PPS, Qualcomm's QC3.0 and QC2.0, and Huawei's fast charging standard.
The only standard missing is OPPO's VOOC, and I wasn't able to charge my Find X9 Ultra to its potential. That said, the phone goes up to 50W over USB PD, and this proved to be handy with the charger.
You get a dedicated DC port
It's the versatility with the DC connector that gives the 30 Ultra an edge over other charging stations. This port goes up to 300W, so you can easily charge power-hungry gaming notebooks without too much of a hassle. You get a smattering of connectors that you can use with the DC port, but note that these will only work when you connect to a notebook.
There's a built-in LCD panel
While most chargers come with a built-in panel these days — I like the ChargeView 140W because of this — Cuktech took it to the next level with the 30 Ultra charging station. It gets a bigger 1.83-inch panel, and it shows real-time charging details, a power curve, and even how much current is going out of a cable.
It's a valuable addition if you've connected several gadgets to the charging station and want to see just how fast individual devices are charging.
Overall, I really liked using the 30 Ultra; Cuktech nailed the design and the port selection, and having two USB-C ports with 140W power is a welcome move. The addition of a DC port is great as well, and the 1.83-inch panel is a nifty inclusion that lets you see in real-time how fast connected devices are charging. If you need a way to declutter your desk with a single charger, the 30 Ultra is a good choice in 2026.
Harish Jonnalagadda
Senior Editor - Mobile
