3 reasons why this 140W GaN charger took over my desk
Satechi ChargeView 140W GaN charger review on Android Central
(Image credit: Apoorva Bhardwaj / Android Central)
I use several chargers throughout the house, and I still rely on the 500W Nexode as my go-to charging station in the office. As good as it is, the charging station is bulky, so I don't use it on my desk. I instead prefer a smaller charger that still gives me the flexibility to charge up to four devices at once, and in recent months, I used Baseus' excellent Nomos 2, which also has a Qi 2.2 mat.
That was before Satechi rolled out its latest GaN charger. The ChargeView 140W is a 4-port charger that's roughly the same size as a regular 140W wall charger, but you get four charging ports in total, and Satechi even managed to fit a tiny panel onto it that shows real-time charging details. The best part is that it costs just $99 on Amazon, which is similar to other 140W chargers I used in recent months. Here are three reasons why the ChargeView 140W is now my go-to desk charger.
The ChargeView 140W is the smallest 4-port charger I used
For me, the number one consideration for a desk charger is the size, and the ChargeView 140W nails the brief. It is smaller than other 4-port charging stations I used, and if anything, it's even smaller than a travel charger.
I also like that it has four USB-C ports; most 4-port chargers include a USB-A port, and while I can understand the reasoning behind that, I don't need the port on a desk charger, so just having a multitude of USB-C ports is highly convenient — at least in my use.
Satechi also includes a stand that lets you orient the ChargeView 140W horizontally or vertically. I used it horizontally, and the stand makes accessing the USB-C ports just a tad more convenient. The charger itself is made out of plastic, and I didn't see any issues with build quality whatsoever.
It has USB 3.2 AVS and goes up to 140W
The ChargeView 140W does a solid job charging four devices at once, and the C1/C2 ports have the ability to charge devices up to 140W. The USB-C1 port uses the latest USB PD 3.2 AVS standard to adjust voltage in minute increments, and it makes a difference while charging the iPhone 17 Pro and iPhone Air.
The USB-C2 port uses the standard USB PD 3.1 profile, and it also goes up to 140W. The C3 and C4 ports go up to a maximum of 40W individually, and these are better-suited for charging handheld consoles and accessories. Like all other GaN chargers, the ChargeView 140W does a good job intelligently managing the power budget based on the number of ports in use. Here's a look at how the power delivering is affected based on number of devices connected:
I used the ChargeView 140W with my Find X9 Ultra, iPad Pro M4, iPhone 17 Pro, and a dozen accessories over the course of the last month. It did just as reliable a job as other GaN chargers I used, and the smaller size and availability of four USB-C ports makes it a long-term addition to my desk.
You get an LCD panel that shows real-time charging info
It isn't that long ago that brands started adding LCD panels to their chargers to show charging details, and I like this feature a lot. The ChargeView 140W has a tiny panel of its own, and it is a great way to see how fast a connected device is charging.
What I like about this is that you can charge the orientation of the panel based on the charger's configuration. So if you're using it vertically, a long press of the button located at the top switches the orientation. It's a small addition, but it's one that makes a noticeable difference.
On the whole, the ChargeView 140W is a great addition to Satechi's charging portfolio, and if you need a reliable desk charger with the ability to charge four devices at once, I'd suggest getting this one.
Harish Jonnalagadda
Senior Editor - Mobile
