This rotating Anker MagGo wireless charger deal is a total head-spinner
Anker MagGo 15W Qi2 Wireless Charger Stand
(Image credit: Anker)
Need a place to keep your phone on your desk while you work? Why not get a stand that wirelessly charges it as well? This magnetic stand from Anker supports 15W Qi2 and MagSafe wireless charging, so you get to recharge your phone without ever plugging it in. And thanks to this final day Prime Day deal, you can score a sweet 20% discount on the Anker MagGo 15W Qi2 Wireless Charger Stand.
Magnets are really great on stands or mounts because you don't need to mess around with clamps, arms, and all that nonsense. And now that magnetic Qi2.2 is catching on in the Android space, iPhone users aren't the only ones who can enjoy the perks of MagSafe products.
Save 20%
Anker MagGo 15W Qi2 Wireless Charger Stand: was $39.99 now $31.99 at Amazon
Anker is the gold standard for charging tech, so you know this charging stand is a reliable buy. Equipped with 15W Qi2 and MagSafe wireless charging, the stand comes with a USB-C cable and can be adjusted at any angle. It tilts and rotates according to your needs. At 20% off, it's a nice little budget purchase.
✅Recommended if: You need a wireless charging stand that is magnetic, adjustable at multiple angles, and supports 15W speeds.
❌Skip this deal if: You want a stand that comes with another charging pad on the base. If that's the case, I recommend getting the slightly pricier Anker MagGo 2-in-1 15W Qi2 Wireless Charger Stand instead, which is 30% off right now.
The Anker MagGo 15W Qi2 Wireless Charger Stand has really powerful magnets, so you can even use the charger with a slim MagSafe or Qi2 case on. Anker promises a speedy 15W wireless charging speed nonetheless.
Since you can rotate your phone a full 360 degrees, you can easily mount it in landscape or portrait orientations. It also tilts, to the point that you can make the mount completely flat, like an elevated pad facing upwards, to charge non-magnetic accessories like earbuds.
The Anker MagGo 15W Qi2 Wireless Charger Stand uses Anker's dependable ActiveShield 2.0 technology to intelligently monitor and manage the temperature of the charging stand. Anker says it measures the device temperature up to 3,000,000 times per day and has built-in protections to help guard against voltage spikes, overcurrent, and overheating.
To add even more reassurance, Anker includes a 24-month warranty. The only thing missing here is a wall charger, but you can use any of your USB-C chargers lying around at home that you use to charge your phone.
If you would like to purchase a dedicated charging brick to go with the stand, Anker's fantastic little Nano Pro 20W charger is just $11.99 on Amazon.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
