Don't trust airport USB ports — this slim power bank has everything you need and is now 30% off
Charging the Google Pixel 9 Pro XL with Google's 45W Pixel charger
Public USB charging ports are convenient, but they're not always something you should rely on, especially at airports. That's exactly why this Baseus Prime Day deal caught my attention. Amazon has knocked 29% off the Baseus PicoGo AM52 MagSafe Power Bank, bringing it down from $80 to just $57.
At its original $80 price, the PicoGo AM52 felt a little too expensive for a power bank. But at $57, it's much easier to recommend. And that's not just because it supports MagSafe or packs a 10,000mAh battery, it's because it solves a few annoyances that most other power banks simply ignore.
Baseus Picogo AM52 MagSafe Power Bank
Save 29% ($23)
Baseus Picogo AM52 MagSafe Power Bank: was $80 now $57 at Amazon
The Baseus PicoGo AM52 MagSafe Power Bank has dropped to $57 for Prime Day, saving you 29%. With a built-in USB-C cable, 45W wired charging, MagSafe support, and a slim 10,000mAh design, it's an easy recommendation for frequent travelers and everyday carry.
✅Recommended if: you want a power bank with a built-in USB-C cable, MagSafe support, a slim design, and a 10,000mAh battery.
❌Skip this deal if: you need a much larger battery capacity or you're simply looking for the cheapest power bank possible.
The timing of this deal is actually pretty good. Last year, the TSA warned travelers about the risks of juice jacking at public USB charging stations. Whether you worry about that or not, charging from an airport USB port also means you're stuck sitting next to it while your phone charges.
That's exactly where the PicoGo AM52 makes sense. What originally launched as a premium $80 accessory is now much easier to justify at $57.
What really sets this power bank apart is the built-in USB-C cable. You don't have to remember to pack an extra cable every time you travel. On top of that, it's fully MagSafe compatible, so you can snap it directly onto the back of an iPhone or Pixel 10 series device.
Baseus PicoGo AM52 MagSafe Power Bank with Built-in Cable
(Image credit: Baseus)
If you're using a MagSafe-compatible case with a Galaxy S26, it'll work there too. And when you need faster charging, just plug in the built-in cable, which supports up to 45W output, plenty for most smartphones.
The PicoGo AM52 also includes an additional USB-C port if you want to use your own cable or charge another device. There are a few other nice touches as well, including a small charging status display and a premium metal construction that makes it feel much more expensive than many plastic power banks.
At $57, it's really hard to find faults in the PicoGo AM52 portable charger. If you've been looking for a travel-friendly power bank that already has everything built in, this is probably one of the better Prime Day deals you'll find.
Sanuj Bhatia
Contributor
Sanuj is a tech writer who loves exploring smartphones, tablets, and wearables. He began his journey with a Nokia Lumia and later dived deep into Android and iPhone. He's been writing about tech since 2018, with bylines at Pocketnow, Android Police, Pocket-Lint, and MakeUseOf. When he's not testing gadgets, he's either sipping chai, watching football, or playing cricket.
