It's simple, it's stylish, and it chargers your phone wirelessly - it's also a little pricey at $59
There's really not a whole lot to say about the Nexus 4 Wireless Charger. It's a $59 Qi-standard compatible wireless charger that charges your Nexus 4. Plug it in, put the phone on it, and go. No muss, no fuss, thank you, drive through. This one's made specifically for the Nexus 4, though presumably other Qi-standard phones will work with it. Unlike, say, the Palm Touchstone, this one relies less on magnets to keep phone in place on the inclined face of the charger and more on the tackiness of the face of the charger itself. The rubber of the charger meets the glass of the phone, and it's not going anywhere. (It is quick to collect dust and lint, though.)
Size-wise, this thing's about like a sawed-off tennis ball. Only less fuzzy, less yellow, and more likely to actually charge your phone. It very much look like it's in the same family as the spherical Nexus Q, but it's much smaller. (In fact, the whole package is smaller than we imagined.)
The wireless charger will kick on the new Daydreams feature -- just be sure to set it to do so while charging in the settings. (It might take a second to kick in.)
The charger comes with a microUSB cord and wall wart, and some quick instructions that you'll never need. Plug it in. Place the phone. Charge. A plus is that your standard TPU case appears to not keep the phone from charging, and the official Nexus 4 bumper doesn't hinder anything either. Because it's a bumper. (Your mileage may vary with other cases, of course.) It outputs at 1.0A, which Google says should take about 4 hours to charge from a dead start.
If you're just dying to see the Nexus 4 wireless charger in action -- which sounds more exciting than it really is -- we've got a brief bit of video after the break.
- Related devices:
- Filed under:
- Tags:
So the Nexus 4 gets its wireless charger pretty much as soon as the phone is released, but the GS3 still has yet to get one that Samsung said they were going to release???????????
3333(forum posts)
