Is HTC's best phone yet enough to challenge Samsung's all-conquering GS7 edge?
There's been more buzz around the HTC 10 than any recent phone from the Taiwanese company. Based on our review, it's clear that HTC has finally addressed a couple of long standing weaknesses, and returned with a modern take on a classic metal-bodied design.
But the HTC 10 doesn't exist in a bubble. It'll have to go up against not only the Galaxy S7, but also its strikingly curvy sibling, the Galaxy S7 edge. As evidenced by Samsung's marketing this time around, the "edge" is the real focus of this year's Galaxy lineup, with a bigger battery, an impressive curved glass design and a larger 5.5-inch display.
So how do these two shape up? We'll put them head to head after the break.
1. Hardware
HTC 10, Galaxy S7 edge
The Galaxy S7 edge and HTC 10 have come to embody their manufacturers' respective design languages. For HTC, it's all about the aluminum unibody — an HTC staple going back to the One M7 — brought up to date with a big, reflective chamfer around the back. For Samsung, the glass sandwich of the Galaxy S7 edge, with its curves on all sides, represent the culmination of what it started back with the Galaxy S6
The HTC 10 isn't the thinnest or lightest Android phone you'll find, but it is a sturdy, well-built handset that's arguably easier to one-hand than the larger, more slippery GS7 edge. That said, the curved glass of the GS7, complemented by its svelte aluminum trim, makes for a phone that's incredibly sleek. HTC's design has more of an industrial look and feel, whereas Samsung's aesthetic is closer to jewelry. The only downside is the GS7 edge's fingerprint-magnet glass back.
The rear glass also allows for Samsung's wireless charging capabilities — support for the Qi and PMA standards, including fast wireless charging if you fork out for Samsung's first-party charger. For good old-fashioned cable charging, you've got a micro-USB port down below, paired with support for Samsung's Adaptive Fast Charging — the Korean firm's implementation of Qualcomm QuickCharge 2.
HTC 10, Galaxy S7 edgeHTC 10, Galaxy S7 edge
HTC can't boast wireless charging, but it does tump Samsung in wired charging, with support for the latest QuickCharge 3 standard, along with a new USB Type-C port, which supports the latest USB 3.1 spec. (That means faster data transfers to and from supporting computers, among other things.)
When it comes to durability, the glass-backed GS7 edge obviously means you've got double the chance of smashing at least one of those panels should you drop the device. However Samsung clearly wins in another key area, with IP68-rated water and dust resistance, meaning it's good under 1.5 meters of water for up to 30 minutes. The HTC 10 by comparison carries an IP53 rating, meaning it's basically splashproof.
Around the front, both phones sport a similar arrangement button arrangement, with a handful of key differences — the GS7's home key is a physical button, whereas the HTC 10's is capacitive (touch-activated). Both double as fingerprint scanners, and on the whole, both handsets are incredibly quick to unlock. We've noticed fewer failures in the HTC 10's scanner however, meaning less frustration in day-to-day use.
The most important part of any smartphone is the display, and although the HTC 10 and Galaxy S7 edge pack a Quad HD (2560x1440) resolution, that's where the similarities end. Samsung uses its own SuperAMOLED technology in one of the very best phone displays available right now, with superlative brightness and daylight visibility, and colors that are vibrant but not obnoxiously over-saturated. Meanwhile HTC's SuperLCD 5 is decent enough, but a tier below Samsung's latest, particularly in daylight visibility.
And true to its name, the Galaxy S7 edge includes Samsung's Edge Screen — mainly a cosmetic feature, though one that's become more useful with additional features like location-aware app shortcuts in Samsung's latest release.
Despite the difference in size — the GS7 edge packs a 5.5-inch display, compared to the HTC 10's 5.2-incher — the overall footprint of these two devices isn't drastically different. Samsung's flagship is ever so slightly taller, but the difference in width — a bigger deal for ease of use — is much more slight.
Internally, both phones pack an impressive assortment of high-end components, including the latest processors from Qualcomm and Samsung, capable camera setups and removable storage. The main internal difference is the GS7 edge's 20 percent lead on battery capacity — 3,600mAh versus the HTC 10's 3,000mAh.
Category HTC 10 Galaxy S7 edge
Operating System Android 6.0.1 Android 6.0.1
CPU Qualcomm Snapdragon 820
64-bit Kryo quad-core
Snapdragon 820 quad-core or
Exynos 8890 octa-core
RAM 4GB 4GB
Display 5.2-inch QHD (2560x1440, 565 ppi)Super LCD 5 5.5-inch QHD (2560x1440, 534 ppi) Super AMOLED
Rear Camera 12MP Ultrapixel + OIS, f/1.8 lens
4K video, 120fps slow motion
12MP + OIS, f/1.7 lens
4K video, 240fps slow motion
Front Camera 5MP Ultrapixel + OIS, f/1.8 5MP, f/1.7
Storage 32GB + microSD 32GB + microSD
Charging USB Type-C
Quick Charge 3.0
microUSB
Quick Charge 2.0 + wireless Qi & PMA
Battery 3,000mAh 3,600mAh
SIM nanoSIM nanoSIM
Waterproofing No IP68 waterproofing
Audio HTC BoomSound Hi-Fi Edition
Two speakers
Downward-facing mono speaker
Dimensions 145.9 x 71.9 x 9.0mm 150.9 x 72.6 x 7.7 mm
Weight 161g 157g
It's also worth noting that although both phones feature removable storage via a micro-SD slot, only HTC supports Android 6.0's Adoptable Storage feature, which allows you to treat your SD card as internal storage.
What's more, HTC's big focus on audio capabilities brings an impressive dual-speaker arrangement — a bottom-facing subwoofer and a single front-facing loudspeaker — along with a powerful amp behind the 3.5mm headphone jack.
Samsung can boast a few exclusive hardware features of its own, however — the aforementioned wireless charging and water resistance, together with a superlative display.
Both have a lot to offer from a hardware perspective, and the choice ultimately comes down to design preference, and whether HTC's audio focus is worth more to you than the additional Samsung hardware goodies.
2. Software
Just about all Android phones have moved closer to Google's vision of the OS in recent years. But much variety remains between the major Android phone makers, including HTC and Samsung.
Both companies have moved away from numbered releases for their own software layers, which sit atop Android 6.0.1 Marshmallow on the HTC 10 and Galaxy S7 edge. Nevertheless, HTC Sense and Samsung's TouchWiz are still worlds apart.
Home screens
HTC has cut back considerably on its visual customizations to the OS, with a UI much closer to vanilla Android. Key Sense features like the BlinkFeed social and news reader remain, and HTC still has its own dialer, messaging and camera apps. But in other areas it's moved away from its own in-house Android apps, instead bundling Google's apps — for example Calendar, Photos and Docs.
HTC's UI is much closer to vanilla Android this year; Samsung follows its own design rules.
Although HTC offers a much cleaner Android experience than in years past, it's still possible to customize it to your own liking through the company's extensive theming system. Like the One M9 before it, the HTC 10 has access to a wide variety of themes for customizing your home screens, fonts, buttons, sound effects, widgets and more. And new in the latest version of Sense, Freestyle mode lets you break free from the shackles of the icon grid, customizing your home screen with cartoonish stickers to launch your favorite apps.
Samsung too has its own theme store, but its base UI is far more visually differentiated, favoring light blues and greys, and rounded rectangular icons throughout. Even the motions of the app-switching menu have been tweaked, with big, swoopy animations when jumping between apps.
Unlike HTC, Samsung has an extensive suite of its own Android apps, from the S Planner calendar app, to its Gallery apps, with includes the ability to create "events" and re-discover past trips through video highlights — a feature handled through the separate Zoe Video Editor app on the HTC side. And of course Samsung also bundled its own Galaxy Apps store, a separate app marketplace for apps specifically designed with the company's phones in mind. (It's also where you'll find apps for the company's Gear wearables.)
Multi-window remains an important differentiator for Samsung.
One of Samsung's most important differentiating features is multi-window — coming to other phones in Android N, but a major Samsung feature going back to 2012's Galaxy Note 2. The GS7 edge's larger display is an ideal fit for showing two apps side-by-side, or overlaying one as a floating window above other content.
Meanwhile, HTC's major focus has been performance, with under-the-hood tweaks allowing the company to claim faster touch response and app-switching — a difference that's there, but not excessively noticeable. Elsewhere, the HTC 10's Boost+ app combines a few dubious functions — bumping apps out of memory as it desires — with more useful stuff like battery optimization for games, and the ability to lock sensitive apps behind fingerprint security.
The choice on the software side comes down to a decision between near-vanilla Android with a handful of differentiated apps on the HTC side, and a feature-rich, if slightly overbearing UI on the Samsung side.
3. Camera
Cameras
With the HTC 10 and Samsung Galaxy S7 edge, both manufacturers are going all-in on smartphone photography, with 12-megapixel optically stabilized cameras around the back, and 5-megapixel selfie cameras.
That's where the similarities end, though. The HTC 10 packs laser autofocus, dual-LED flash and an f/1.8 lens for its main "Ultrapixel 2" camera, which features large 1.55-micron pixels on the sensor for superior night photography. Over on the GS7, Samsung's camera features 1.4-micron pixels, but behind a brighter f/1.7 lens. Both are reasonably close on paper, but the differences between the two come down to post-processing more than optics — an area in which Samsung still has a slight lead.
As a result, the GS7 is the more reliable shooter, even though HTC's camera is impressive in its own right. While both perform well in a wide variety of situations, Samsung's camera routinely captured more fine detail, especially in HDR mode. The HTC 10's camera also produced generally softer looking images that could appear more washed out than Samsung's in certain daylight conditions.
HTC has a slight lead in some low-light scenarios, with the HTC 10 being able to capture more realistic colors in night scenes, though with more chroma noise.
Any other year, HTC might have been able to boast of having the best Android phone camera.
That said, both phones can boast a place among the best phone cameras of 2016, with fast launch times, speedy captures and generally reliable performance across the board. If we were forced to choose, however, we'd have to go with the GS7 — mainly because of its slightly sharper focus, superior macro performance, and easy double-tap home shortcut for quickly loading the camera app.
Around the front, HTC pulls ahead with the first optically-stabilized selfie camera, which does a great job of capturing decent-looking pics even in low light. Like the HTC 10's rear camera, focus can be a little soft, but the front camera's all-round performance makes up for this.
All in all, we're looking at two really great phone cameras, each suited to different kinds of photography.
4. Battery life
HTC 10, GS7 edge
With an additional 600mAh of juice, Samsung has the lead on paper when it comes to battery capacity. And as we've found using the HTC 10 and Galaxy S7 edge as daily drivers in recent weeks, that advantage — perhaps combined with more efficient internals — translates into a noticeable lead in battery life for the Samsung device.
HTC claims two-day battery life, but that's not realistic.
Whereas HTC markets the 10 as having "two-day" battery life, we've found this only plays out with light usage on Wifi. Once you start venturing out and using LTE with the screen brightness upped, it's remarkably easy to kill off the HTC 10 in under a day. It's hardly alone in that respect, but it's worth pointing out that HTC's battery life is far from the claimed breakthrough.
Meanwhile we've found the GS7 edge to be a reliable contender, particularly when travelling, or browsing over LTE for extended periods. (What's more, Samsung's camera setup seems far less punishing on its battery than HTC's.)
Numbers-wise, we're seeing between 12 and 14 hours per charge with heavy use from the HTC 10, with 3.5 to 4 hours of screen on time. By comparison, Samsung's gotten us comfortably to the end of the day, with 16 to 17 hours per charge, and up to six hours of screen-on time.
When it comes time to charge, both phones benefit from rapid charging through Qualcomm QuickCharge, with the HTC 10 being one of the first to support QuickCharge 3 for even speedier charging than Samsung using the bundled brick.
5. Bottom line
HTC 10, GS7 edge
Both the HTC 10 and Samsung Galaxy S7 edge are great phones that perform well across the board. Both handsets are worth your cash, and either will provide a phenomenal, future-proof Android experience.
In our view though, Samsung's phone has the lead in a few crucial areas, notably battery life, camera experience and display quality. That's not to say HTC is disappointing in those areas, just that the Galaxy S7 edge has set the bar really high.
There are, however, a few areas of personal taste involved. The GS7's fingerprint magnet back panel might be a turn-off for some, who may prefer the cold metal of the HTC 10. And at the same time, HTC's doing a lot of impressive stuff with audio in its 2016 flagship.
HTC is the nearest Android rival Samsung has right now, and so the contest between these two handsets won't be conclusively settled anytime soon. Nevertheless, our opinion is that Samsung's still ahead — but with a serious competitor in the HTC 10.
