DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Samsung's marketing campaign for the new Samsung Galaxy S III (S3) focuses heavily on how the visuals and sounds in its software are "inspired by nature." But one of the less welcome results of this is the water droplet sound that plays every time you press an on-screen button, menu or widget. Thankfully there's an easy way to make this quieter -- or completely silence it -- if it's not your cup of tea. Check out the video above for a quick walkthrough.
There are 19 comments
tommydaniel says:
I like that you can control the volume level, rather than just off or on.
The question is can you CHANGE that sound.?
Alex Dobie says:
Nope. Though I guess if you're rooted you could find the sound file and replace it with something else.
butters619 says:
I have no clue, but I would imagine you could. Even if you couldn't officially change sounds through a menu, you could probably find the system sounds folder and just drop your sound in there with the same file name.
btc0526 says:
That's exactly what you do
rovex says:
I just replaced the sound files with a simple click. You need root though, but its easy enough. The files are called TW_Touch.ogg and S_HW_Touch.ogg. I just copied and renamed one of the other files on the phone. I have them backed up for when i flash a ROM.
vinny jr says:
I also changed the file to the basic generic click sound. I saved the stock file to flash back when I want to. Very simple but need root.
Nev says:
If you disable the water droplet, you disable nature...and by disabling nature, you disable the very essence of the Galaxy S III. You might as kick my dog or cut down a rain forest.
CeluGeek says:
You don't disable nature; you just get it into a drought.
Cubfan says:
So should this be headlined "How to turn your Galaxy S3 into a Galaxy S2"?
NickAVV says:
I cannot believe that that sound effect made it into a retail device. That would drive me absolutely crazy
joebob2000 says:
Most other phones have some sort of obnoxious click on screen press enabled by default. Turning that off is the very first thing I do when changing ROMs, even before I log into Google or change the background all those damn noises get turned off.
NickAVV says:
Android's stock clicking noises aren't nearly as annoying, nor as loud as that sounds from the video
hmmm says:
Even stock Android uses a click sound on touches. I can't believe anyone would want to hear a click or any other sound for everything...
ggr says:
Isn't that the beauty of Android? You can customise almost everything about your phone and make it your own?
I was sure, we could turn off the volume .....before I read the article or had a chance to hold my S III in my hands ...
Cola-X says:
If you're going to make an instructional video, then follow through on your instructions.
CeluGeek says:
I do use the click sounds of stock Android or pre-GS3 Touchwiz, but that water drop sound is extremely annoying!
jfs101 says:
I only have that sound on the phone keypad. And it's not annoying at all.
yeah answer me this, how can we change the sound? can we download different tones?????
