I put a Bluetooth sleep speaker under my pillow and it's way better than a phone for bedtime listening
The Jabees Peace Pillow Speaker in the hand and on a pillow.
(Image credit: Brady Snyder / Android Central)
If there's one thing consumers in the audio market have proven over the past few years, it's that they like hearing sound without having something in their ears. That's why bone-conduction headphones, open earbuds, and even smart glasses with open-air speakers have taken off. Now, audio brands are trying to figure out how to use these technologies to enhance the listening experience while sleeping.
It might sound odd to those who haven't tried it, but many people enjoy listening to white noise, podcasts, audiobooks, or music as they fall asleep. Some try to use their everyday earbuds for this purpose, which can be uncomfortable for side sleepers. Others buy a dedicated pair of sleep earbuds, like the great Soundcore Sleep A30 I previously tested. And a few just use their phone speaker under their pillow, hoping for the best.
None of these options is perfect, but Jabees is trying to provide another alternative with a Bluetooth speaker designed to go under your pillow. I've tested it, and although it's not perfect either, it seems like the best option for side sleepers who don't love wearing earbuds to sleep.
How the Jabees Peace Pillow Speaker works
The Jabees Peace Pillow Speaker is small enough to fit in your hand, and that might be surprising. It certainly wasn't what I expected when this audio accessory came in the mail. After spending time with it, the pillow speaker's compact and portable size may be its biggest strength. I tend to have trouble sleeping while traveling, because my body's internal clock gets thrown off, and having a tiny pillow speaker I can bring with me for white noise or music listening sounds appealing.
It works by using a variation of bone conduction, similar to that used in bone-conduction headphones. Although it's marketed as a bone-conduction pillow speaker, that's not exactly the best way to describe it. Bone conduction headphones work by sending sound vibrations through the bones in your cheek, which are perceived by your inner ear. By comparison, this pillow speaker works by sending sound vibrations through your pillow, which can then be heard by your ear.
Putting aside the marketing discrepancy, the important thing is that it works. With the speaker under your pillow, it amplifies the vibrations, making them easy to hear at medium-to-high volumes. You're supposed to put the speaker under the part of your pillow where your ear is expected to rest. Location matters if you want to get the best experience.
The Jabees Peace Pillow Speaker in the hand showing the buttons and ports.
It's a Bluetooth speaker, but this device can also run independently using audio files stored on a microSD card. A 1GB card is included with the "plus version," and it comes with eight white noise and nature sounds. The standard version is only about $4 cheaper, so you should go with the plus bundle if you plan to use the white noise sound. Those who only want to connect to their phone can skip the microSD card and save a few bucks.
There are three yellow, high-visibility buttons for on/off and volume control. Some of these buttons serve multiple functions, like how the power button is also used for pairing, and the volume up key is used for a sleep timer. Speaking of, that feature is handy if you don't need your music to play all night — it can auto-stop after 30 minutes, an hour, or two hours.
Using a Google Pixel 9 Pro XL for scale to show the size of the Jabees Peace Pillow Speaker.
Using a Google Pixel 9 Pro XL for scale to show the size of the Jabees Peace Pillow Speaker. (Image credit: Brady Snyder / Android Central)
The battery lasts up to 10 hours, meaning you'll get a full night's sleep from the speaker, but not much more. Using the sleep timer might help you get a week out of it. Charging via USB-C is pretty easy: just plug the pillow speaker in where your phone charges overnight, then wake up.
It's better than your phone, but worse than sleep earbuds (for some)
The Jabees Peace Pillow Speaker on a pillow next to a smartphone.
The price is important to keep in mind here — it's $36 for the standard version or $40 for the plus bundle with a microSD card. That should give you an idea of how the Jabees pillow speaker will sound. The quality isn't outstanding, but it blows a phone speaker away by a mile. That's because a phone speaker fires its best audio out the bottom, while this pillow speaker sends sound vibrations upward through your pillow.
When using it, you'll have to decide whether you want the pillow speaker to be discreet or loud. At a volume I'd consider comfortable, it is loud enough that someone sleeping next to you might be able to hear it. Lower volumes are less intrusive to partners, but work better for subtle white noise than for music and podcasts you need to hear.
If it's between a phone speaker and the Jabees Peace, give me the dedicated pillow speaker. As a side sleeper, I get louder volumes and enhanced clarity compared to my phone without uncomfortable earbuds in my ears. I also like being able to use my phone or set it on a nightstand while keeping the music playing under my pillow. However, it won't be for everyone.
The Jabees Peace Pillow Speaker between a pillow and a couch.
Sleep earbuds still win for those who need high volume without disturbing a sleeping partner. Additionally, premium options like the Soundcore Sleep A30 have gradual morning alarms that this pillow speaker can't replicate. While it's a rare winner for side sleepers, those who sleep on their back may not be able to hear the pillow speaker well enough.
Save for those edge cases, the Jabees Peace Pillow Speaker is an intriguing option for those who need audio to fall asleep. It's particularly great for its portability, and it seems like a perfect companion for those who need extra help sleeping while traveling.
Brady Snyder
Contributor
Brady is a former contributor for Android Central, who wrote for the site from 2023 to 2026. With a focus on news, phones, and audio, he spent years reporting and commenting on all things related to consumer technology.
Brady reviewed Apple, Google, Samsung, and Motorola phones for Android Central, and attended industry-wide events like IFA and MWC on behalf of the publication. He holds a bachelor's degree in journalism from St. John's University.
His work has been published in XDA, Android Police, Android Authority, MakeUseOf, and SoundGuys, among other sites. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
