Tablets are essential travel companions, and I've selected the TOP 9 devices you should consider before hitting the road in 2026
OnePlus Pad 3 Angled View on Deck
(Image credit: Andrew Myrick / Android Central)
Whether you're preparing for a long flight or a road trip, tablets have become must-have additions to any summer travel packing list. The best tablets for travelers should have great battery life, good-looking displays, and enough power to access your favorite streaming services or games without skipping a beat.
But with so many options to choose from, how can you select the Android tablet that's best for you and your needs? It's going to depend on a few factors, from budget and size to use case, so before you hit the road, let's take a look at the best Android tablets for travel in 2026.
What is the best tablet for travel?
As with most device purchases, the right tablet for you really depends on how you plan to use it. Need a versatile device with incredible battery life? The OnePlus Pad 3 is probably the best all-rounder, with impressive performance, a stunning display, and a reasonable price tag to match.
Need a laptop replacement? Devices like the Samsung Galaxy Tab S11 Ultra can handle heavy media consumption and large file management with ease. There are also plenty of great options if you just need an e-reader or something kid-friendly. Needless to say, we've tested all of the tablets listed above and can vouch for their quality, regardless of your needs or budget.
What features should I look for in a tablet for travel?
The tablet you choose for your journey should have a nice display, a lightweight-yet-durable build, and enough battery life to handle those long travel days. The dimensions are important as well, so take a moment to think about the size of your luggage before you commit to a specific model. If you want to use accessories like a detachable keyboard or stylus, it's also important to confirm that the tablet is compatible.
Last but not least, I'd recommend confirming that the device you choose has enough storage to hold all of the stuff (movies, games, etcetera) that you need for those long trips when you won't have access to a cellular connection or Wi-Fi network. Some tablets might even come with a microSD slot so you can expand your storage capacity if necessary.
TOPICS
Patrick Farmer
eCommerce Editor
