The most popular accessories for your Motorola Droid Bionic
Motorola Droid Bionic Accessories Roundup
We know searching for the best accessories for the Motorola Droid Bionic can sometimes be confusing with all the choices available out there.  Whether you're looking for a case to protect against drops, an extended battery to keep your Bionic powered up all day or even bluetooth speakers so you can enjoy your music anywhere you wish-- here at Android Central we carry the best assortment of accessories for your new Motorola Droid Bionic smartphone.
Let's dive into this edition of Accessories Roundup by checking out the top five most popular accessories for the Droid Bionic:
Our top Motorola Droid Bionic accessories
Chosen not only by the expert staff here at Android Central, but most importantly you- the customer.  Out of all the accessories for the Droid Bionic we stock, we've picked out the most popular cases, chargers, batteries, bluetooth and other components that we feel are detrimental to keeping your Motorola Droid Bionic powered up, safe and sound.
Best cases for Motorola Droid Bionic
Seidio SURFACE Case
Seidio SURFACE
Case
Seidio CONVERT Combo
Seidio CONVERT
Combo
Qmadix Snap-On Cover
Qmadix Snap-On
Case
When it comes to cases for the Motorola Droid Bionic everyone has there own specific tastes in terms of the level of protection they desire.  For the more average every-day user, the Seidio SURFACE case offers a decent level of protection with its thin, form fitting hard plastic shell.
If you're looking to kick it up a notch, say three-layers of protection, then the Seidio CONVERT Combo is right up your alley.  Not only does this Droid Bionic case combo feature a hard case, skin case, and exoskeleton-- it comes with a sturdy swivel holster to clip onto a utility belt.
Another great option to protect your Motorola Droid Bionic is the Qmadix Snap-On case.  This hard shell case wraps around your device like a glove with very little bulk.  It also comes with a swivel clip holster.
Best batteries for Motorola Droid Bionic
Motorola Droid Bionic extended battery
Motorola 2880mAh
Extended Battery
Motorola Bionic standard battery
Motorola Standard
Battery
Making sure your Droid Bionic has plenty of battery life is extremely important if you plan to make it through the day, so why not take advantage of one of these handy batteries for the Motorola Droid Bionic.
The Motorola 2880mAh extended battery for Droid Bionic is the largest cell available and comes with a replacement battery door since it's just slightly thicker than the OEM battery.  Definitely a great option for the power-user who can't get enough juice with just a standard battery.
Carrying a spare replacement standard battery for the Motorola Droid Bionic is also an option if you don't care for modifying your device with a larger battery door.  When your original battery runs down, just pop in your replacement and you're ready to rock.
Best chargers for Motorola Droid Bionic
Motorola HD Multimedia Dock
Motorola HD
Multimedia Dock
Motorola Car Charger
Motorola Car
Charger
Motorola HDMI Cable
Motorola HDMI
Cable
Want to stay juiced up? Then take a look at these popular chargers and cables for the Motorola Droid Bionic.  The Motorola HD Multimedia Dock is our most popular accessory for the Droid Bionic.  It features a remote for easy accessibility to your media while viewing on your home TV as well as 3 USB ports on the back to support peripheral devices and an audio-out port.
If you're planning on traveling then the Motorola high performance car charger is the top pick amongst our customers. Its OEM quality and rapid charging speed allows you reach your destination fully charged.
Lastly the Motorola HDMI cable plugs into any standard HDTV, allowing you to display any multimedia on your Bionic.
Other Motorola Droid Bionic accessories
Jawbone JAMBOX
Jawbone
JAMBOX
Motorola Droid Bionic Screen Protectors
SPE Screen
Protectors
Clingo Mount
Clingo
Vehicle Mount
SanDisk 32GB microSD card
SanDisk
32GB microSD
Let's not forget the accessories that still play a big part in protecting and fully utilizing your Motorola Droid Bionic.  The Jawbone JAMBOX is a bluetooth speaker that you can pair to your Bionic to stream your favorite tunes.
Protecting your Motorola Droid Bionic isn't limited by what kind of case you choose, but also a quality screen protector.  Avaiable in packs of two, these Droid Bionic screen protectors are anti-glare and and be easy cleaned then reapplied.
Utilizing your Droid Bionic shouldn't ever be a hassle when your managing your calls or using the navigation feature while traveling.  The universal Clingo Vehicle Mount allows you to simply stick your device to the pad on the Clingo ensuring the safety of your Bionic from bumps or swift turns.
You'll want to keep plenty of space available on your device so you don't hinder the functionality of the Droid Bionic.  Thankfully the 32GB microSD card from SanDisk offers plenty of room to store your favorite music, movies, apps and personal data.
The wrap-up
Hopefully by now you've found the right accessories to compliment your new Motorola Droid Bionic smartphone and are ready to take full advantage of your Android experience.  Remember that we're always adding new accessories to the Android Central Store for the Droid Bionic as well as many other popular Android smartphones emerging on the market. So be sure to check in to see the latest and greatest accessories for your Android.
There are 4 comments
TheMan876 says:
Bionic? *yawn
*No disrespect Brent. ;D
radgatt says:
We need more variety
Life34 says:
Definitely need more variety...
Just a Guy says:
How long until the price slash on the Bionic?
