If you're going to do any light traveling with your Motorola Xoom, check out the Belkin Grip Sleeve. It's more than just a basic sleeve. Along with the durable neoprene (think wetsuit), it's got a textured surface so you don't lose your grip while holding it. (Thus the name.)
The sleeve sports a dual-zipper closure, is lightweight, and you can wash it off with soap and water. The inside is plenty soft, and it's not going to scratch your Xoom. It's also loose enough to allow you to store a few papers inside, too.
All in all, it's a simple way to protect and carry your Motorola Xoom. The Belkin Grip Sleeve is available now for $37.95 from the Android Central Store. We've got more pictures after the break.
- Related devices:
- Filed under:
- Tags:
2439(forum posts)
