Keep your phone powered with batteries for Motorola Droid Bionic
You'll want to be sure that your Motorola Droid Bionic stays juiced up throughout the day.  Although the standard battery that comes with your Droid Bionic may be enough power for some, there's always the power-user that needs more than just the norm.  The good news is we provide standard batteries for the Motorola Droid Bionic if you prefer to carry a spare at all times, as well as extended batteries which usually come with a larger door to replace the original, but offer an exceptional amount of additional talk and standby time.
Motorola Droid Bionic batteries
Batteries for Motorola Droid Bionic
Batteries for the Motorola Droid Bionic are a must have if you are always on-the-go and don't have access to a wall or car charger.  Simply replace your standard Droid Bionic battery with this OEM replacement and you're all set.  Many people opt to carry two or more Motorola Droid Bionic batteries at a time, leaving no reason to worry in case they run out of juice.
Extended batteries for Motorola Droid Bionic
Extended battery for Motorola Droid Bionic
For those who require that extra battery life without having to swap cells, the Motorola Droid Bionic extended battery is a sound choice to stay powered up hassle free.  Bundled with a larger door to replace your original battery door, this extended capacity battery provides nearly double  the amount of battery life as the original cell.
Best selling Motorola Droid Bionic batteries
Recent Motorola Droid Bionic Batteries Stories
Droid Bionic
Article
by Casey Rendon
Apr 12, 2013
Android 4.1.2 will be pushed to devices in phases Droid Bionic users can expect an OTA starting Monday, changing software build numbers to 98.72.22.XT875. This is Android 4.1.2 Jelly Bean, ...
Article
by Andrew Martonik
Apr 03, 2013
Turns out that Motorola support page may have been right after all After a puzzling update to Motorola's support documentation for the Droid Bionic that indicated it would receive Jelly Bean...
Article
by Andrew Martonik
Mar 26, 2013
While we wouldn't have blamed you for thinking ICS was the end of the road for the Droid Bionic, a Motorola Support page now indicates that a Jelly Bean update is on its way in Q2 2013. The hand...
Android Central
Article
by Alex Dobie
Oct 23, 2012
Long-suffering Motorola Droid Bionic owners, your Ice Cream Sandwich update has finally arrived. The Bionic, which has languished on Gingerbread since its release last fall, is today being bumped up...
Article
by Andrew Martonik
Oct 18, 2012
Remember when we started hearing about a Droid Bionic soak test? Yeah, that's happening now. Verizon has just put up official documentation on its support site for the update -- software version...
