Light Flow
27 new apps now compatible with the service, including Google Keep
One of the most popular notification sound, vibration and LED control apps, Light Flow, is picking up a notable update with a refreshed interface and lots of compatibility improvements. First off you'll notice a refreshed white interface that takes advantage of new design and animations popularized by Google Now. The developer now makes use of the "card" UI for selecting notifications in the settings and for newly refreshed widgets.
On the back-end, the update brings compatibility fixes for the Galaxy Note 3 as well as other Samsung phones using its Knox enterprise security suite (provided you're not rooted). As usual the app adds new app compatibility, and this time around we see 27 new supported apps including Google Keep and the official BBM client.
If you're a fan of Light Flow you'll want to give this one an update — the design refresh is a lot friendlier and the widgets are much easier on the eyes. If you like it, consider buying the full version, it's just $2.49 to support a great developer.
