(Yes, you'll need instructions)
You really shouldn't need an instruction manual to remove the microSD card from a phone. But things get a little tricky with the Samsung Infuse 4G.
Open up the battery cover and there's no card to be found. OK, there's a picture of one on the FCC label, but where the heck is the card? Samsung tucked it up under the SIM card. It's spring-loaded and pops out straight down toward the bottom of the phone.
But that's not the only trick -- it's mounted face down. You'll need to make sure the printed side is down, and the gold contacts are facing up.
As for actually getting your fat fingers around and under the card to remove it? You're on your own. Check out our trials and tribulations after the break.
- Related devices:
- Filed under:
- Tags:
2438(forum posts)
