Lloyd
Shop Android
Entourage Edge
Here's a very brief look at a non-working Entourage Edge. So, we can't really comment about how the e-ink display (that's the one of the left) works in conjunction with the Android-powered LED side of the brain on the right. But we can tell you that this thing is large. You're not going to be packing this thing in a pocket for some easy reading. But the clamshell hinge was strong, and the buttons large. So it has that going for it, which is nice. Couple more shots after the break.
Entourage Edge
Entourage Edge
Filed under:
Tags:
Be the first to comment! Login or Register now!
