Droid Incredible Batteries | Android Central
Order Samsung Galaxy S8: AT&T | Verizon | T-Mobile | Sprint
Pre-Order Unlocked Galaxy S8: Best Buy
Batteries for your Droid Incredible
Droid Incredible standard battery
The standard Droid Incredible battery (seen here in its fire-engine-red paint scheme) is of the 1300mAh variety. (That's a unit of measurement for the amount of juice a battery holds. A higher number means a bigger battery.) While 1500mAh is by no means small, the Droid Incredible is, shall we say, a bit of a power hog. So you might want to consider keeping a spare on hand, just in case.
Evo 4G extended battery by Seidio
The Droid Incredible extended battery brings more juice -- 1750mAh -- in the same size as the stock battery. That's about 17 percent more juice, all without needing a bigger battery door or adding any bulk to the phone.
