DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Droid 2
For those of you with a Motorola Droid 2 in your hands, get ready for an update that should be hitting devices soon. As posted on the Verizon site, the change log for the v4.5.621 software update has been posted and here's what you can expect:
Device Features
  • Device is enabled with the Wireless Alerting System. + A Google Security Patch has been added to improve security level.
  • Fixed issue where the device may power ON without user interaction.
  • Adjusted camera settings will be saved, even after the device is powered down.
  • Resolved possible device resets while playing music.
  • Reduced Out of Memory errors.
Email, Messaging & Data
  • Improved ability to access and receive Gmail messages when the Mobile Hotspot is turned on.
  • Addressed error that replicated thumbnails in message threads.
Applications & Widgets
  • WAV files can be played from Visual Voice Mail.
  • Purchased ringtones are now able to be downloaded, saved and used where appropriate.
SD_Shadow from the Android Central forums has noted a few things about the update as well, such as the fact that it appears to break root and possibly even break SBF functions. If you're looking for more discussion, head on into the forums. If you've already got the update, drop a note in the comments and let us know how it's working for you.
Source: Verizon; Via: Android Central Forums
There are 6 comments
TechKayaker says:
What is the "Wireless Alerting System"
mattyb1085 says:
If it's anything like the Alert app that is on the Atrix 2, it can be configured to show weather alerts, amber alerts, etc.
silverfang77 says:
What do you mean "coming soon"? The patch has been out for two days already.
AndroidOne says:
From the dictionary post above:
"Coming soon: We actually have no friggin' idea when it's coming. But if we say "coming soon," it makes it look like we know when it's coming. We're mysterious like that."
3rdpig says:
That reminds me, I need to charge my D2 up and get it on ebay while it's still worth something.
MikeB1970 says:
I did this update last night, and now my notification/status bar is gone from the top of the phone. Anyone know how to turn it back on?
Atleast I can upgrade at the end of the month, I am getting the Razr Maxx : )
