  • OnePlus will begin rolling out the OxygenOS Open Beta 4 for the OnePlus 7 and 7 Pro next week.
  • The update adds new "Raise to lower the ringtone" feature and support for transfer of iPhone data through iCloud.
  • Along with new features, the OxygenOS Beta 4 build for the two phones also includes several optimizations and bug fixes.
OnePlus has announced the latest OxygenOS Open Beta 4 for the OnePlus 7 and OnePlus 7 Pro, just two weeks after releasing the OxygenOS Open Beta 3 for the two phones. However, the latest Open Beta 4 build is currently available only for some OnePlus 7 Pro users.
In a post on OnePlus forums, the company said that its team is currently addressing an issue with the build, which is the reason why owners of the OnePlus 7 will have to wait until next week to try it out.
The Android 10-based OxygenOS Open Beta 4 for the two phones comes with several optimizations, improvements, and bug fixes. There are a few new features too, such as "Raise to lower the ringtone" gesture in Sounds & Vibration for incoming phone calls and support for transferring data from an iPhone through iCloud with the help of the OnePlus Switch app. It also adds The Weather Channel as a data source for the OnePlus weather app.
VPN Deals: Lifetime license for $16, monthly plans at $1 & more
Here's the full changelog:
System
    Fixed the screen flashing issue with setup while adding the fingerprint
    Fixed the issue of the accidental muting of a vehicle navigation system with a Bluetooth connection
    Fixed the disabling of mobile data after an upgrade
    Optimized visual effects of the permission's pop-up window
    Optimized the black and white screen issues with some apps
    Improved system stability and fixed other known issues
Phone
    Added the "Raise to lower the ringtone" feature in Sounds & Vibration for incoming calls
    Enabled efficient addition of unknown numbers to contacts
    Optimized the description for the features
    Expanded the dial pad area to avoid mis-touches
    Optimized the message sorting feature by verification code
Calculator
    Optimized UI and interactive experience
OnePlus Switch
    Supported transfer of iPhone data through iCloud
Weather
    Added The Weather Channel as a data source for accurate weather data
While the Open Beta 4 build isn't available to download yet, some users have reported that they were able to download and install it on their OnePlus 7 Pro with the help of the third-party Oxygen Updater app. If you own a OnePlus 7, however, you will not be able to get the build early, even if you use the Oxygen Updater app.
Get More OnePlus 7
OnePlus 7 Pro
We may earn a commission for purchases using our links. Learn more.
