Sprint pushes Android 5.1 to Galaxy S6 and Galaxy S6 edge
The Android 5.1 update for the Samsung Galaxy S6 and Galaxy S6 edge is now pushing out from Sprint. This update, which is rolling out to users over-the-air, brings a number of bug fixes along with it. In addition, the update also includes stability improvements, additional security options, and other enhanced features.
It may be a day or two before you see the notification on your device, but you can always check for the update manually. Simply head into the Settings, scroll down to About Device and then check for the update. If you have already received the update, be sure to let us know in the comments below any changes or issues you are noticing.
Source: Sprint (1),(2)
