Aukey's 10400mAh power bank is just $22 on Amazon
Aukey is offering its 10400mAh power bank for only $17 on Amazon with the use of coupon code ** 6PHZZRAF**, down from its original $40 price. Featuring two full sized USB ports, one of which utilizes Qualcomm's Quick Charge capabilities, the power bank also has a microUSB port and a flashlight. Aukey supplies a short microUSB cable, but you can use any existing cable that you already have with the power bank.
10400mAh should be anywhere from two to five full charges, depending whether you are charging a tablet or smartphone. Remember, you'll need to use coupon code ** 6PHZZRAF** at check out to receive the full discount.
Purchase the Aukey 10400mAh power bank from Amazon for $22
This post may contain affiliate links. See our disclosure policy for more details.
