Source: Android Central
- A new Samsung battery with model number EB-BG980ABY has been certified in South Korea.
- The listing reveals the battery has a 3,730mAh rating and is likely to be used in the Galaxy S11e.
- Chinese tipster Ice Universe suggests the Galaxy S11+ may pack a massive 5,000mAh battery.
Samsung's next-generation Galaxy S11 series phones are shaping up to be very impressive upgrades over this year's Galaxy S10 series. A new leak now suggests the Galaxy S11 series will not only come with some significant upgrades in the camera department but may offer much better battery life as well.
The folks over at GalaxyClub have discovered a listing for a new Samsung battery with the model number EB-BG980ABY on South Korea's Safety Korea website. As per the model number of the battery, it is going to be used in an upcoming Samsung smartphone with the model number G980. The Galaxy S10e bears model number SM-G970, so there is a good chance that the SM-G980 will arrive as the Galaxy S11e.
Source: Safety Korea
The image included in the listing isn't high-res, but we can still see that it is rated at 14.36Wh. Since it operates at 3.85 volts, the minimum capacity of the battery would be 3,730mAh. Its typical capacity, on the other hand, could be somewhere around 3,900mAh. The Galaxy S10e has a 3,100mAh cell.
Chinese tipster Ice Universe has noted that the different shape of the Galaxy S11e's battery suggests the smartphone will have a new motherboard design as well. He has also suggested that the bigger Galaxy S11+ may arrive with a 5,000mAh battery, which would be a significant upgrade compared to the 4,100mAh battery found inside the Galaxy S10+.
Despite a bigger battery, the Galaxy S11+ is unlikely to be a massive improvement over the Galaxy S10+ in terms of actual battery life, as it is rumored to have a high refresh rate display as well as 5G connectivity.
We may earn a commission for purchases using our links. Learn more.
Review: Xiaomi's 34-inch ultrawide gaming monitor is astonishingly good
Xiaomi's ultrawide gaming monitor is now available outside of China for the first time, and it delivers an incredible value in this category. The monitor uses a Samsung VA panel and has 144Hz refresh rate along with FreeSync. Is this the best budget ultrawide gaming monitor around? Let's find out.
The Galaxy S20 FE is still the best Samsung phone you can buy
Samsung makes a lot of great phones, from $2,000 foldables to $200 budget options with massive batteries. These are the best Samsung phones you can buy in 2021.
LG leaving Android isn't good for anyone — except LG
At some point, throwing money into the sea will start to look like a bad idea and LG will just call it quits. I hate those kinds of days.
Best USB-C Audio Adapters for Galaxy S20 & Galaxy S21 in 2021
Without a headphone port, you'll appreciate having an audio adapter to go with your Galaxy S20. Here are the best options you can find to use whatever headphones you'd like.
