Finding the right case for your phone is like picking a wand in Harry Potter. Try as you might, you can't ever force one on yourself; the right case always seems to choose you. Fortunately for me, I think I've finally found my one true case in the Mobi Products Honeycomb TPU Case for the HTC EVO 3D.
While there's no shortage of anti-dust, rubberized material, no-slip cases out on the market, the Honeycomb TPU Case has one glaring difference: its design. While it comes off as "just another case" from the front, once you flip this bad boy over, you'll be getting nothing but compliments at how cool your case is.
Up top you've got the standard 3.5mm headphone jack opening, but curiously enough, Mobi Products opted to cover the power button completely, leaving their own plastic button cover in place. It doesn't feel bad, but sometimes you lose the truly tactile clicking feeling that only comes from an uncovered button. They give the same treatment to the volume rocker, too.
On the same bezel as the rocker there's an opening for the camera button and 2D/3D slider, as well as openings for the microphones down bottom and the micro-USB charging port on the left.
The case itself is relatively thin, but just tall enough to peer over the camera lenses, which means you can finally leave your phone on its backside without worrying about scratching everything up. Add in the fact it's slick in your hand but grippy when on a surface, and you've definitely got a winner in the "cool look, great price" category of phone cases.
More pictures are after the break.
- Related devices:
- Filed under:
- Tags:
30(forum posts)
