Source: Chemex
Best Pour Over Coffee Makers Android Central 2021
Avid coffee drinkers want their java to be perfect. As a fellow coffee lover, I expect perfection and consistency in every cup. Coffee needs to be an experience rather than just a drink. We think the pour-over coffee method is probably the best way to make and drink coffee. We recommend the Chemex Classic Series Coffee Maker as our choice for the best overall pour-over coffee maker. It is made of high-quality borosilicate that does not impart any other flavors, so you can make a brew as strong as you like without bitterness.
- Best Overall: Chemex Classic Series Coffee Maker
- Best Value: HIC Harold Import Co. 2664 Coffee Filter Cone, No.4, Black
- Best Cone: Hario V60 Ceramic Coffee Maker
- Best for Entertaining: Bodem Coffee Maker
- Best for Gifting: COSORI Pour Over Coffee Maker
Source: chemexcoffeemaker
The Chemex Classic Series Coffee Maker is a timeless coffee maker with a visually appealing design. It features an hour-glass design that makes waiting for your perfect cup a delight. Made from Borosilicate glass, this pour-over coffee maker is non-porous and will not absorb odors. The purity of the resulting coffee can be stored in the fridge for later without losing any of the flavors.
With a capacity of three cups or one pint, the Chemex is very easy to use and is dishwasher safe. Just remember to remove the wooden handle first. You can also hand wash it with warm soap and water; it really is low maintenance. The Chemex Classic Series Coffee Maker comes equipped with a wooden center to keep your hands protected from the heat. You won't have to worry about accidentally scolding your hands while pouring a cup for yourself and a close friend. Regardless, be careful as the wooden handle may slip.
Pros:
- Non-porous material gives a clean taste
- Aesthetically pleasing
- Stylish wooden handle
Cons:
- The wooden handle may slip
Source: Amazon
For those of you who are looking for the biggest bang for the buck, we suggest this plastic coffee filter cone from HIC. It is cheap and designed for manual pour-over coffee brewing and has the capacity for 8 to 12 cups.
The plastic is lightweight, food-safe, and non-breakable so that you can carry the cone with you. Once you get used to brewing your coffee this way you will want to let your friends know about it, or even buy them the same. They will appreciate you even more. This coffee filter cone is easy to clean, dishwasher safe, and simple to use. This cone has four holes at the bottom to deliver the coffee, so care should be taken not to quickly pour the water over the coffee as it may spill over.
Pros:
- Plastic material is lightweight and easy to clean
- Great value for low cost
- Easy to clean
Cons:
- Cone protrudes into the cup and may displace coffee
- Not a kitchen showpiece
Source: Hario
The Hario V60 sits on the top of your mug or carafe while brewing and comes in a variety of colors so you can pick one that suits your decor. The single large hole can change the coffee taste according to the speed of water flow, so you will need to gain some experience to reach your optimum taste. The experimentation will be worth it.
This is a dishwasher safe coffee dripper that is easy to use and brews one to three cups of coffee at a time. Smart innovation is the spiral ribbing on the inside of the cone that allows for maximum expansion of the coffee. It is a personal choice, but many drinkers prefer the ceramic model since the ceramic body retains the heat for a constant temperature throughout the brewing cycle. Unfortunately, the water flow rate may cause the paper filter to break.
Pros:
- Full control over the coffee-making process
- Ribbing in the cone allows for coffee expansion
- The ceramic material is non-porous
Cons:
- The large hole may cause the filter to break
Source: Bodum
We all like friends coming over, but this coffee maker may make them stay. The slow brew will intoxicate the nostrils as the permanent steel mesh filter will not trap any essential oils that a paper filter would. The borosilicate glass delivers a clean-tasting brew that you can repeat again and again. An elegant design, this Bodum Coffee Maker will make a beautiful addition to your kitchen.
Pour a small amount of water in a circular motion over the coffee until it is soaked and then add the rest of the water. Then just enjoy the drip. It makes eight cups of coffee and is dishwasher safe. That goes for the steel mesh also.
The thin glass can lose the heat quickly.
Pros:
- Stainless steel mesh filter
- Dishwasher safe
- Large sizes available
Cons:
- Pour slowly as the coffee may spill over
- Not really suitable for one cup brewing
Source: COSORI
If you know someone who is just thinking of switching to pour-over coffee, this one is a great gift option. It provides full control and customization of the brewing process, allowing you to adjust water temperature and flow as well as coffee ground concentration to your liking.
The borosilicate glass decanter can hold up to 34 ounces of coffee or about eight cups, enough for entertaining as well. And it comes with a stainless steel filter that allows the fine oils of the grounds to infuse the coffee. Plus, it's easy to clean in the dishwasher (along with the decanter) and eliminates the need for paper filters. Because the decanter is thermal-resistant, you can even heat up the water on the stovetop using a low flame.
The coffee maker comes with everything you'd need, including a BPA-free scoop, solid wooden sleeve, and a handy manual that has professional tips and coffee-to-water ratios to help you get started.
Pros:
- Stainless steel filter
- Dishwasher safe
- Thermal-resistant decanter
- Manual with pro advice
Cons:
- Can only hold up to 8 cups
- Expensive
Bottom line
Drinking coffee is a personal experience that should be enjoyed to the full extent. So when it comes to selecting the best overall, why not go with the classic Chemex Classic Series Coffee Maker. It's a very stylish pour-over coffee maker that will give you years of consistent quality, and look good in the kitchen. We believe this coffee maker is the best in combining form and function.
It delivers consistent, high-quality coffee, so you can concentrate on enjoying rather than worrying about the taste. And with the non-porous material, you can expect that clean taste every time you brew. Plus, the stylish wooden handle gives it that little extra touch. It's the perfect choice for any pour-over coffee lover.
Credits — The team that worked on this guide
Parminder "Parmy" Virk is a freelance writer who has been writing news releases for public companies. He is a sports enthusiast and loves life.
Christine Persaud resides in Toronto, Ontario, Canada, with her husband and 8-year-old son. When she moved from a condo to a house five-and-a-half years ago, she switched every bulb in the home to LED and went a step further to have a Savant home automation system installed to control them.
We may earn a commission for purchases using our links. Learn more.
Whip up a fancy drink with one of our favorite milk frothers
Ordering a cappuccino in a coffee shop can set you back a bit. And if you treat yourself daily, your money goes down a sinkhole quickly. Make fancy drinks at home for less than a third of the price by using a milk frother and your ingenuity. These are our favorite frothers this year.
Up your caffeine game with your very own cold brew coffee maker
If you live and die by your caffeine intake, take control with a new cold brew coffee maker. These models top our list of favorites.caffeine
Compress the coffee to get the best espresso
A busy barista is at risk for repetitive strain injuries, so it’s important to have a tamper that is comfortable to use. Once you have a decent tamper, you can start working on using proper technique to prevent injuries on the job. We have listed some tampers to help you choose the best one for you.
