Meross is offering its MSG100 Smart Wi-Fi app-controlled garage door opener for just $38.49 at Amazon. To get this price, you'll need to use coupon code F8S8IMA7 during checkout. This is one of the most affordable options that we've ever seen, and this matches an all-time low for this popular opener.
No hands needed
Meross Smart Wi-Fi App-Controlled Garage Door Opener
Gone are the days of needing to have a physical button to open your garage door. Use this smart controller accessory to add voice and smartphone control to your door.
$38.49 $69.98 $31 Off
With coupon: F8S8IMA7
The Meross MSG100 is a smart garage door opener that was originally crowdfunded back in November 2018 on Indiegogo. It adds remote and voice control easily to your existing garage door opener and doesn't require any extra hub or anything like that. It's compatible with both Amazon Alexa and Google Assistant, and you can use the Meross app to turn your phone into a garage door remote control. You can get notifications that let you know whether the door is opened or closed, overnight notifications that help remind you to close it, and more. It comes with strong adhesive that you use to install it, making the entire set up process quick and painless. Users give it 4.1 stars based on over 50 reviews.
See on Amazon
This post may contain affiliate links. See our disclosure policy for more details.
