Samsung releases app to restore missing quick setting toggles on Galaxy S6 and S6 Edge
Samsung has released an app called QuickPanel Restore on the Galaxy Apps store that should restore toggles for certain settings in the quick settings panel that mysteriously went missing from some users' Galaxy S6 and S6 Edge devices.
Samsung still hasn't mentioned why the quick toggles went missing in the first place, but if you found that some quick setting toggles went mysteriously missing from your device recently, you can head to the Galaxy Apps store now and search for QuickPanel Restore. After it's downloaded, you can open the app and click on the "Restore" button and all should be well again. Let us know if it works for you in the forums or in the comments below.
Sources: Android Central Forums, SamMobile
